Author Topic: 2.9 4x4 starter.  (Read 1769 times)
2.9 4x4 starter.
« on: April 26, 2012, 13:15:00 PM »
2 Days ago my starter on the Mk2 packed up. :'(
I had the starter especially built as the steering column was fouling the relay.
I've moved the steering rack a bit since I first fitted the V6, so I might be able to put on a normal starter.
However there seem to be 2 or 3 types of starter.
There is a 1.1 kW one and 2 1.4kW ones.
I want a 1.4 kW one but the parts suplier doesn't know which one it is.
I'm I right in thinking the 4x4 starter is shorter as the drive shaft interferes with the starter otherwise?
I never had a standard starter fitted so I don't know.
Does anybody have the original partnumber for a 2.9 4x4 starter? (I can't look it up as Microcat expired)
Re: 2.9 4x4 starter.
« Reply #1 on: April 26, 2012, 19:25:35 PM »
I found these numbers for the 1.1 kw with 9 teeths: 88BB11000BA - 91GB11000AA-91GB11000AB-  91BB11000KA - 91BX 11000KA - R88BX11000BA
Hella: 8EA 730 195-001.
« Reply #2 on: April 26, 2012, 22:36:48 PM »
2.9 Xr4x4's only have 1.4KW starters fitted.
When Microcat expires just reset your date to say the year before, make sure auto update is off & re-boot.
It should now work.
Offline sierra3dr
« Reply #3 on: April 27, 2012, 09:41:11 AM »
