Author Topic: Cosworth 24v boa  (Read 6287 times)
Offline ---2.8 INJECTION---
Cosworth 24v boa
« on: September 25, 2011, 16:58:54 PM »
I'm currently fitting a boa in my capri but am not sure on where all the pipes go which are at the back of the engine, there I's a big pipe on the underneath of the plenum, a smaller pipe coming of the o/s cam cover and then the valve with another hose on the n/s cam cover, Any helpon where these hoses go would be very helpful
Re: Cosworth 24v boa
« Reply #1 on: September 26, 2011, 08:07:24 AM »
The big pipe with the pcv valve goes to the valve cover. the other valve cover has a pipe at the back and that one goes to the airfilter box.
Offline REGMCI
« Reply #2 on: September 26, 2011, 10:41:47 AM »
Quick quick, make a presentation of you and your car!
Don't Scrap it, Restore it!
Ford Taunus
« Reply #3 on: September 26, 2011, 12:53:05 PM »
Ok that's very helpfull thanks, any idea where the big one from the underside of the plenem chamber goes though?
« Reply #4 on: September 26, 2011, 20:13:18 PM »
« Reply #5 on: September 26, 2011, 22:03:19 PM »
I'm on about the pipe which I's right on the underside of the plenem chamber not the one on the cam cover with the pcb valve, i was thinking possible for brake servo?
« Reply #6 on: September 26, 2011, 22:07:23 PM »
Or am i missinderstanding you and u mean that the pipe from the underneath goes to the pcv valve which goes into the valve cover?
« Reply #7 on: September 27, 2011, 07:55:41 AM »
There is no connection for the vacuum for the brakes.
There are 2 big pipes, one comes from underneath the plenum and goes to the valve cover. A other is on the back, underneath the plenum and goes to the egr.
For a vacuum connection for the brakes, you can use this one, if you dont use the egr (i would advise the use the egr system) or fabricate a t piece in this pipe.
