nearly sorted with the front suspension setup now.
just need to sort the antiroll bar out on the front as the angles are too much for the rose joints
the coilovers were brought from Ebay second hand as an unknown quantity, but appear to be Avo units. The mounts my friends dad made up were too tight unfortunately, and due to the lack of articulation on the spherical bearing end it sheared a damper rod
So a new unit and a big more machine work to the mounting spacers ensued, and now running 950lb 7inch springs which seem to be quite compliant ride wise
Just need to call up the 2 Steves and get booked in for mapping up the ole girl at long last
