Author Topic: new lad  (Read 2793 times)
burt24v
new lad
« on: September 07, 2008, 00:14:14 AM »
hi all it feels good 2 b on ford power 2 know i will have your support {hopefully} in my 24v conversion i'v got a 1.8 lx saphira with full cossie kit   boa fitted but not wried with a 5 speed gearbox form a 1982 granada 2.5 derv . i lv this car and need 2 finsh it soon
Offline Mik
new lad
« Reply #1 on: September 07, 2008, 07:45:27 AM »
Welcome mate. Sounds like you're well on your way to getting on the road. There's not much that these guys don't know and should get you closer to finishing your project.
Mik.
burt24v
new lad
« Reply #2 on: September 07, 2008, 19:34:37 PM »
thanks mate i hope so the wiring is do mi head in
Offline kevchard
new lad
« Reply #3 on: September 07, 2008, 20:50:32 PM »
Quote from: burt24v
Hi Burt
I live in Donny, but work in Barnsley. I can give you advice on BOA wiring if you get stuck, as i wired the BOA into our Cobra replica.
Where abouts in Barnsley are you?
Kevin
burt24v
new lad
« Reply #4 on: September 07, 2008, 21:33:26 PM »
Hi Kevin, At the moment i'm living with a mate in elsecar but otherwise i live in maltby.
     I have tried wiring it up twice, the first time i could get a spark but no fuel from the injectors and the second time it reversed its self, i could get fuel but no spark.
     I have got most things wired up and ready, its just the spark and fuel problem i need to sort out
new lad
« Reply #5 on: September 08, 2008, 07:47:21 AM »
Welcome to Ford Power
burt24v
new lad
« Reply #6 on: September 09, 2008, 09:30:36 AM »
thank you leebay it feel's like one big happy famly here
Offline kevchard
new lad
« Reply #7 on: September 09, 2008, 11:12:43 AM »
Hi Burt
Where is the car located?
Kevin
PS private message me if you want a chat about possible causes.
burt24v
new lad
« Reply #8 on: September 09, 2008, 21:44:27 PM »
Alrite mate the car is located at maltby and i think im going to go thru on saturday and have a play with it,
on  your wiring diag that you attached, where it says power splice is this where you attach the ignition live?
Cheers Burt24v
Offline kevchard
new lad
« Reply #9 on: September 10, 2008, 08:15:52 AM »
Hi Burt
The Power Splice is the battery +ve that that is distributed to all the high power circuits in the engine bay. The power splice is not live all the time and only becomes live when the ECU tells relays 10 and 12 to 'turn on'. When the car is 'ready to run' all the power slices should be 12v (effectively connected to each other then to the battery via the relays).
I would start checking your earths to make sure you have enough of them and they are all joined together. Sounds like an intermittant problem you have there.
Kevin
burt24v
new lad
« Reply #10 on: September 11, 2008, 16:46:46 PM »
hi kevin
ive been and got another loom from a j reg but i didnot get the ecu with it
will i be abill two use my ecu with the new loom as mine was from a h reg
+ would it b possible 2 meet up with u if i come through to doncaster
i cant find were i should connect my ignition live as well
thanks burt
Offline kevchard
new lad
« Reply #11 on: September 11, 2008, 19:07:54 PM »
Hi Burt
ECU is same on all BOAs (early proper granada shape) cars .
You can by all means come through to Donny (balby).
PM me and i will give you y phone number.
Kevin
