Author Topic: 24v starting problems, please help  (Read 2186 times)
magic randy
« on: November 08, 2007, 11:06:45 AM »
got a 24v BOA v6 fitted with emerald ecu
turns over and over then stops
or
turns over and fires one cylinder pos two, but still fails to start.
with lambda sensor out it flames out of hole but still doesnt start
want any sugestions simple or complex
with as much detail as possible and pics or diagrams
thanks in advance
dev
« Reply #1 on: November 08, 2007, 19:20:45 PM »
Did this setup run before?
Do you have a standard ECU to try?
Try spraying easystart into one of the vacuum stubs on the side of the throttle body as you start the engine. This will help decide if it's fuel or ignition?
spanner
« Reply #2 on: November 08, 2007, 20:42:26 PM »
Don't use easy start! feck me TT that stuff's lethal should have been banned years ago.
Super 12v
« Reply #3 on: November 09, 2007, 06:41:32 AM »
On the emerald, can you see CPS readings whilst cranking? I find it easiest to read when plotted as a line graph over time. what sort of speed can you see? and does it plateaux and hold? Make sure there no blips or spikes as these will be misreadings, and you'll need to check gapping or wiring. Once you've established a good CPS feed to the ECU i'd then start looking at fuel and spark scenarios.
BTW maybe worth checking but from what I've seen of BOA conversion it's appears quite common for the fuel return and feed to get mixed up. maybe worth checking
Rob
« Last Edit: November 09, 2007, 06:43:48 AM by Super 12v »
« Reply #4 on: November 09, 2007, 08:48:28 AM »
Yes fule feed/return mixup is common as is pump control problems, missing earts, failed FPR's.
Jimboxr4x4
« Reply #5 on: December 04, 2007, 23:29:22 PM »
Fuel filter? - mine did exactly the same when the filter got blocked.
glyn
« Reply #6 on: December 05, 2007, 08:36:50 AM »
Quote from: Jimboxr4x4
check if the 2 relays are coming in ie fuel pump,is it runing when ign is switched on,see if you got a spark when cranking take a pluglead off ,put a spare plug in the lead and hold to the engine,have someone to crank the engine,you should see a spark.to check for fuel loosen fuel feed to engine,not the return mind and carfully with a n empty tin see iff you have a full pipe when ign switched on,it will only be for a sec mind,also you can check the white and black large electrical connectors to the engine loom,these can play up...good luck glyn
