Author Topic: Scorpio In for MOT  (Read 5043 times)
Scorpio In for MOT
« on: October 25, 2007, 08:54:55 AM »
Well My scorpio moved the furthest it has in two months this morning, all the way to the MOT center.
It's probably going to fail. But with 10 days for a free retest and a £45 fee I should be able to sort any minor bits and get it roadworthy again.
Scorpio In for MOT
« Reply #1 on: October 25, 2007, 15:21:05 PM »
Quote from: TwinTurbo
Goodluck
Scorpio In for MOT
« Reply #2 on: October 25, 2007, 19:49:19 PM »
SnoopDog has a shorter wrap sheet!!!
I assume these two or the rigid lines on the arms.
3.6.B.2C Nearside Rear Flex-Flex brake pipe corroded
3.6.B.2C offside RearFlex-Flex brake pipe corroded
This ?  Typing error?
3.6.B.2C offside Rear  Frount-Flex brake pipe corroded
Arse!
Offside Rear Chassi Leg Subframe mounting excessive corrosion
I suspected these may fail as they have rubbing damage
4.1.C.1a    4 x tyres which
Argh!
2.4.C.1A  Incomplete Coil Spring
Not sure on this one?
2.2.B.1H Nearside front ( drum stick ) steeting arm has relative movement at it's fixings?
And they did not do the emissions as they said there was a large leak at the fannymould.
So not a great result.
glyn
Scorpio In for MOT
« Reply #3 on: October 25, 2007, 20:03:47 PM »
does drum stick refer to the rack /pinnion arm coming out of the rack?..glyn
spanner
Scorpio In for MOT
« Reply #4 on: October 25, 2007, 23:21:40 PM »
You pissed when ya typed that TT or is that actually whats on the fail sheet? sure as hell aint what the propper wording is on the MOT computer I can tell you that much. Guy wants shooting!
Scorpio In for MOT
« Reply #5 on: October 26, 2007, 08:48:06 AM »
Little pissed but the items, are what's written on the sheet.
Nearside front ( drum stick ) steeting arm has relative movement at it's fixings. 2.2.B.1H
Nearside Rear Flex-Flex brake pipe corroded. 3.6.B.2C
Offside Rear Flex-Flex brake pipe corroded. 3.6.B.2C
Offside Rear Frount-Flex brake pipe corroded. 3.6.B.2C
I have asked automec for a price on a full set of lines.
Chuck W
Scorpio In for MOT
« Reply #6 on: October 27, 2007, 13:59:46 PM »
"Drumstick" sounds like it might be the outer tie rod end??  I guess that kind of looks like a drumstick
Then again, I guess it depends on whether they are referring to a drumstick you eat instead of one you bang on drums with......
« Last Edit: October 27, 2007, 14:00:43 PM by Chuck W »
Scorpio In for MOT
« Reply #7 on: October 27, 2007, 22:23:23 PM »
god knows, I thought at first it may be an ARB droplink. but I wonder now..
Scorpio In for MOT
« Reply #8 on: October 28, 2007, 15:39:32 PM »
Yep track rod, inner ball joint has movement.
Chassis leg needs welded on inner face.
Brake likes have flaking paint but don't look bad! still can't work out what is ment by fronunt flex pipe? the rigid lines look fine there. And the spring has snapped maybe 1" off the end of the bottom coil.
Scorpio In for MOT
« Reply #9 on: October 28, 2007, 20:47:17 PM »
Actually that is not to bad.
Cheap but a bit of work involved.
Good job your a DIY man
Scorpio In for MOT
« Reply #10 on: October 28, 2007, 21:54:27 PM »
It would be easier if the MOT man ( normal guy was ILL ) could put down accurate information!
Looks like the rear beam will need dropping for the chassis welding.
fordparts do the track rod for under 40.
doglegsxr
Scorpio In for MOT
« Reply #11 on: October 29, 2007, 01:36:04 AM »
when i had the fester in for it's mot he said my front drumstick had a bit of play in it i persume he ment the tie rod
spanner
Scorpio In for MOT
« Reply #12 on: October 29, 2007, 21:12:59 PM »
Well I been 25 years in trade and never seen anyone call a track rod end a drum stick. Plain stupid that is when the correct failure clearly states EXCESSIVE PLAY IN A TRACK-ROD END BALL JOINT.  He can't even have selected correct failure for it other wise it would have incorperated the text above plus any additional wording he chose to enter.
I wonder if he's meaning the inner end of the arm at the knuckle under the gaitor boot. If so he should have selected INNER TRACK - ROD.
Is it power steering Rob? wonder if the numpty had the sense to check for play with engine running?
Scorpio In for MOT
« Reply #13 on: October 29, 2007, 21:26:30 PM »
There's defo play in the inner joint the wheel has definite movement that is not in the TRE.
£38 for a replacement arm from FordParts.
The guy was shipped in from west cumbria to cover illness. God knows why he could not work the system.
spanner
Scorpio In for MOT
« Reply #14 on: October 29, 2007, 21:38:54 PM »
aint many motors you won't find a bit of play there to tell the truth. Have you checked it with engine running Rob? Thats how it should be checked if it's power steering. At end of the day the mot book states EXCESSIVE play and if when wiggling steering wheel slightly the road wheel movement is positive it can hardly be classed as excessive. More pass & advise but one testers opinion varies from next sadly. The usuall thing these days COMMON SENSE is no more.
« Last Edit: October 29, 2007, 21:39:57 PM by spanner »
doglegsxr
Scorpio In for MOT
« Reply #15 on: October 30, 2007, 23:14:34 PM »
is the inner track rod easy to replace not done an inner one before outer ones were easy enough, but as keith said may be down to there not being any pressure there with the engine not running. still mean to jack the fester up and try that with ignition on to see if the play goes away, probably the next mot will have come back around again by the time i check it then again the tester will have forgotten by then lol :D
