Author Topic: 2.9 poly vee pulley spacers  (Read 1297 times)
Offline tane
  • Member
  • iOS 11.4 iOS 11.4
  • Safari 0.8.2 Safari 0.8.2
« on: August 07, 2018, 19:00:41 PM »
I know the changes are small, but would somebody happen to have the spacers for 2.9 12v poly vee pulleys, water pump and crank?
Also circled in red in the picture
  • Windows 10 Windows 10
  • Edge 17.17134 Edge 17.17134
Re: 2.9 poly vee pulley spacers
« Reply #1 on: August 11, 2018, 07:22:45 AM »
If you cant find them. Someone with a lathe should be able to make some spacers.
Offline tane
  • Member
  • iOS 11.4 iOS 11.4
« Reply #2 on: August 11, 2018, 08:21:01 AM »
I managed to find the waterpump spacer and planning to take the lathe route with the crank spacer. I measures my crank pulleys and it seems that the best one is actually from a bob, so would still have to modify the original spacer if I found one.
