Author Topic: 24v parts wanted  (Read 2792 times)
Offline Heath Robinson
24v parts wanted
« on: February 18, 2016, 23:24:49 PM »
Hi all.
After a few bits, first lot hopefully fairly cheap as I intend to hack them about a bit!
All for a BOA -
Inlet manifold in whatever condition.
The part that sits in the valley, and the thermostat housing bolts to. Has the temp sensor screwed into it.
Maybe also the thermostat housing too.
Secondly, I'd like to find a good condition timing blade for the BOA (I know, hen's teeth etc) and any other timing bits that might be useful - I have a good chain, NOS tensioner and NOS guide (the easy one to find). Also those little friction plates that sit above the chain between the sprockets in the heads.
Finally, if the price is right, a BOB short engine & cams, or whole engine. Don't need the ancillaries, or even the timing gear. Just a decent bottom end, and the cams.
I know that's a long list of wants, but I'm not in any hurry, so let me know what you have!
Jake
Re: 24v parts wanted
« Reply #1 on: February 21, 2016, 23:11:03 PM »
Is this one part?
« Reply #2 on: February 23, 2016, 00:43:35 AM »
Yeah, I think that's the thermostat parts! I'll check it against my engine tomorrow, thanks rob.
Offline adams 2000e
  • Hi, I'm new here...
« Reply #3 on: February 23, 2016, 09:33:52 AM »
I have an inlet plenum available. make me an offer.
postage wont be cheap as it is heavy or I am based in poole, dorset.
Offline cal
  • Firefox 44.0 Firefox 44.0
« Reply #4 on: February 23, 2016, 16:07:39 PM »
i think i have everything you want. Got a complete BOB/BOA hybrid, also some BOB cams.....However i live in Barbados so postage will be fairly high. No longer using the engine, in fact it may even be seized..... will check if you interested
couple other parts as well....2.8 granada flywheel, performance coil pack, magnecor plug wires, 6 sets of piston rings, 3 sets of valve seals
possibly more if i search
« Reply #5 on: February 26, 2016, 00:03:40 AM »
PMs sent to all and sundry, apologies if you get no response from me for a week or so, I'm going to France for a bit.
