Home
Help
Search
Calendar
Login
Register
FordPower
General
General Discussion
Where can you get an input shaft modded in london/south east?
Please
if you find this site helpful & wish to help with it's funding. Thank You.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Where can you get an input shaft modded in london/south east? (Read 3775 times)
capri71
Full Member
OS:
Mac OS X 10.7.5
Browser:
Safari 6.1.2
on:
March 28, 2014, 11:04:36 AM »
A fella wants to buy my old gearbox but wants it modded to go on a 4 cylinder (its a V6 one) so the input shaft has to be shortened. Who could i recommend? or send it to for him? Cheers
Logged
capri71
Full Member
OS:
Mac OS X 10.7.5
Browser:
Safari 6.1.2
Re: Where can you get an input shaft modded in london/south east?
Reply #1 on:
March 28, 2014, 11:34:07 AM »
Its a type nine btw
Logged
cossiemk2
Administrator
Hero Member
Reply #2 on:
March 28, 2014, 13:03:10 PM »
Just grind the excess off and round the edges off.
IIRC it's 2 cm longer than a 4 cylinder.
Logged
capri71
Full Member
OS:
Mac OS X 10.7.5
Browser:
Safari 6.1.2
Reply #3 on:
March 28, 2014, 13:06:11 PM »
where do you grind it back from? the end? simple as that?!
Logged
capri71
Full Member
OS:
Mac OS X 10.7.5
Browser:
Safari 6.1.2
Reply #4 on:
March 28, 2014, 14:44:49 PM »
can anyone confirm that i just cut 20mm off the end, smooth the edges, done? the fella wants me to do it for him now AND put in a crate and send it to sri lanka
Logged
cossiemk2
Administrator
Hero Member
Reply #5 on:
March 29, 2014, 15:21:38 PM »
The nose of a v6 is longer.
The splines where the clutch sits is the same for all engines.
IIRC it's 2 cm. But I never had a 4 cylinder box so I can't confirm this for you.
Logged
Administrator
Hero Member
OS:
Windows 7/Server 2008 R2
Browser:
MS Internet Explorer 10.0
Reply #6 on:
March 29, 2014, 19:24:04 PM »
There is a 1.2 inch difference between the shafts. Also in some cases the splines are futher back than the v6 input shaft, depending on the casing.
You could modify them, but you still have take the gearbox apart. it would be easier to just swap the shaft.
A other downside is that when you shorten the shaft, it will lose its strength because you remove it hardened surface and I have seen these modified ones break.
http://www.type9gearbox.co.uk/type-9-variations.html
A new input shaft is still available for around £69,-
http://www.bearingkits.co.uk/1.6/1.8/2.0-TYPE-9-GEARBOX-INPUT-SHAFT-18-TEETH/156.htm
Maybe someone has a 4 cylinder shaft for sale or check the bay.
Logged
capri71
Full Member
OS:
Mac OS X 10.7.5
Browser:
Safari 6.1.2
Reply #7 on:
March 30, 2014, 00:26:05 AM »
Ah ok not gonna do it for him then…. for sale as is, end of. cheers fellas
Logged
Print
Pages: [
1
Go Up
« previous
next »
FordPower
General
General Discussion
SMF spam
blocked by CleanTalk
