Author Topic: Mt75 geabox to engine dowels ?  (Read 8468 times)
Offline whiteestate
  • Safari 5.1.7 Safari 5.1.7
« on: July 21, 2013, 15:56:53 PM »
Does anyone know where i can get a set of these for my boa engine to mt75 gearbox ? Think there is 2 iirc ?
Re: Mt75 geabox to engine dowels ?
« Reply #1 on: July 21, 2013, 20:33:56 PM »
Burton do them mate
Offline whiteestate
« Reply #2 on: July 21, 2013, 20:42:41 PM »
They do the 12.7mm 1/2'' think the ones i need are 15.2mm ?
« Reply #3 on: July 21, 2013, 21:32:29 PM »
I think that's the ID, they are the ones listed for cos 4x4 etc mt75.
Offline whiteestate
« Reply #4 on: July 21, 2013, 21:53:44 PM »
Burton no longer list them by the looks of it so i bought some 15mm thick wall stainless steel pipe should do the trick.
« Reply #5 on: July 25, 2013, 23:04:23 PM »
Make sure they fit exactly mate otherwise you will get vibrations.
It's the dowels that line everything up, the bolts just keep it together.
« Reply #6 on: July 26, 2013, 19:23:25 PM »
It's the dowels that line everything up, keeps parts from moving and the bolts just keep it together.
Fixed  :angel:
Offline whiteestate
« Reply #7 on: July 27, 2013, 01:20:22 AM »
i have 15.2 mm on the bell housing holes so with the 15mm stainless dowels i can have a maximum of 0.4mm to play with is this too much?
Don't know what the block measures but I'm sure its going to be around 15mm surely !?
« Reply #8 on: July 27, 2013, 05:59:29 AM »
I will have a look for you today mate, I may have a couple in my garage somewhere.
  • Chrome 28.0.1500.72 Chrome 28.0.1500.72
« Reply #9 on: July 27, 2013, 23:27:26 PM »
Fixed  :angel:
lol
No mate the reason I said that is a gearbox I built failed at around 10K & the guy went mad blaming me & also his mate blamed me who owned the garage who put the box in for him.
He helped me take the box out & there was no dowels fitted.
I showed him all the damage caused by not having the dowels fitted which you could see as the box was a good 4 mm + off centre.
His new clutch, gear set & front bearings were all shot.
He fell out big time with his so called mate at the garage who fitted it & sold the car cause he was sick of it!
Was a bit of a hot head  :rolleyes:
My advice would be fit the proper thing whiteestate or machine the pipe the same.
Also the dowels for Cologne heads are the same diameter, maybe you can get them.
I take it Ford don't have any then ??????
« Reply #10 on: July 28, 2013, 07:46:47 AM »
These are common dowels size as ford uses them a lot. They are also used between the block and head on most 4l, v6 and v8's.
« Reply #11 on: July 28, 2013, 09:37:39 AM »
I have some in a block for the heads, they measured the same as the box ones but not sure on the length or I have some stainless tube 16.06 od and 11.6id.
I'm sure I got some off burton recently for the new engine but I would need to check my receipts for the part no. The head ones are http://www.burtonpower.com/catalogsearch/result/?q=Tv1442
Offline whiteestate
« Reply #12 on: July 28, 2013, 14:49:28 PM »
I'm going to pop down to fords tomorrow and have a look to see what they have got as my pal is the parts manager so he should let me have a look at a few types the stainless rod i have got is going to be too loose as the dowels are usually a tight fit.
Offline mk22door
  • Mac OS X 10.5 Mac OS X 10.5
  • Firefox 3.6.28 Firefox 3.6.28
« Reply #13 on: July 29, 2013, 20:21:26 PM »
I'm going to need some of these so keep us posted  ;)
Offline mk22door
« Reply #14 on: August 29, 2013, 21:28:56 PM »
What did you end up doing here then?
You get sorted?
Offline whiteestate
  • Safari 6.0.5 Safari 6.0.5
« Reply #15 on: September 06, 2013, 20:28:09 PM »
Ford do actually do them i have picked 2 up yesterday and will fit them sunday ford tried to give me the 1/2'' ones saying they were correct until i showed them the correct item on the parts finder. They are 15.2mm diameter and are the same for all cologne v6 engines
Offline mk22door
« Reply #16 on: September 07, 2013, 15:54:04 PM »
You got a finis number for them & I'll get some ordered  ;)
Offline whiteestate
« Reply #17 on: September 22, 2013, 20:33:32 PM »
Heres the part number you need 2
Offline mk22door
« Reply #18 on: September 27, 2013, 12:45:01 PM »
Many thanks
 ;D
