Author Topic: EGR system  (Read 6035 times)
Offline doga-ot
EGR system
« on: May 14, 2013, 22:13:07 PM »
I have just fitted a BOA into my saph and have kept all the EGR engine is in now and everything is fitted except the EGR anyone have pics so I can see how the pipes go etc many thanks
WES
Offline tabetha
  • Chrome 28.0.1500.95 Chrome 28.0.1500.95
Re: EGR system
« Reply #1 on: August 15, 2013, 14:43:10 PM »
Ditch the EGR is the best bet!!
Re: EGR system
« Reply #2 on: August 15, 2013, 19:28:11 PM »
Keep it. The engine will run smoother en beter with it with less fuel consumption. The reason is that the BOA ecu doesn't compensate for the loss of the EGR, so it will have a wrong fuel/air mixture when the EGR should be working. The ecu will detect a lean condition, but cannot compensate fast enough.
1 vacuum hose comes from the throttle body and goes to the vacuum solenoid, from there it goes to the EGR. One hose comes from the exhaust manifold and goes to the exhaust pressure transducer. That's it.
Offline Gareth
  • Firefox 23.0 Firefox 23.0
    • http://www.trinityschoolracing.co.uk
Re: EGR system
« Reply #3 on: August 15, 2013, 21:51:34 PM »
Interesting, when I had my Scorpio 24V blanking off the egr made a noticeable improvement. I'd have thought the fuel trims would have taken car of the lean condition?
Re: EGR system
« Reply #4 on: August 16, 2013, 08:03:25 AM »
Like I said, the ecu will detect a lean condition, but cannot compensate fast enough. This is manly the fault of the slow reacting and limited range of the lambda sensors.
The BOA ecu doesn't compensate for the loss of the EGR, so it doesn't turn of the EGR function.  The ecu runs a different fuel/air map and adjust the timing when the EGR is active. Now, you remove the EGR, the ecu still keeps using the EGR mapping, hence a drop in performance in the midrange rpm (lean condition and wrong timing).
To compensate for the lean condition in the midrange rpm, some people use bigger injectors, but this can cause other fuel/air problems because the ecu is not setup for the bigger injectors.
Offline mk22door
  • Mac OS X 10.5 Mac OS X 10.5
  • Firefox 3.6.28 Firefox 3.6.28
Re: EGR system
« Reply #5 on: August 16, 2013, 11:30:23 AM »
I take it this is okay when you are using an aftermarket ECU?
Re: EGR system
« Reply #6 on: August 16, 2013, 19:11:00 PM »
With a aftermarked ecu, removing the EGR is not a problem.
Offline Dave2302
Re: EGR system
« Reply #7 on: August 17, 2013, 12:51:31 PM »
Not a problem on the BOB EECV either.............
I can switch the EGR off in the binary, so the ECU no longer references the EGR multipliers, and no fault code comes up  ;)
Cheers Dave
It's nice to be important but
Offline tabetha
Re: EGR system
« Reply #8 on: August 17, 2013, 16:30:28 PM »
I can't understand modders using the std ecu, sorry I mistakenly assumed they'd ditch that first.
tabs
Offline Dave2302
Re: EGR system
« Reply #9 on: August 17, 2013, 19:17:40 PM »
Only because no one could map them, lets face it a Ford EECV is a far better ECU than anything that the aftermarket has to offer.
The problem was that there was no definition info for them, each Ford EEC has different address locations, uses different strategy.
With help from a buddy who used to program I have got the 24V ECU sussed now and can alter over 150 diffent perameters  ;D
Cheers Dave
Re: EGR system
« Reply #10 on: August 17, 2013, 19:27:35 PM »
Tweecer uses caledit witch has the def and cal files for the 24v boa ecu's, so you can mod you own ecu. The plan was to also do this with the bob ecu's.
That's true. even a eec iv is superior to most aftermarket systems.
Offline scud
Re: EGR system
« Reply #11 on: August 20, 2013, 20:38:33 PM »
can these be upgraded without replacing the ecu?
Re: EGR system
« Reply #12 on: August 20, 2013, 20:58:34 PM »
No. The ecu hardware is setup for the small range lambdas, not for a wide range lambda.
Offline scud
Re: EGR system
« Reply #13 on: August 27, 2013, 18:40:23 PM »
yeah it did seem to easy
Offline Dave2302
Re: EGR system
« Reply #14 on: August 28, 2013, 09:32:25 AM »
When I switch off the EGR on the EEC V because the ECU then knows there is no EGR fitted, its strategy then no longer refers to the EGR fuel and ignition multipliers, so therefore the engine will not be leaned off or advanced up by the ECU, so yes it does work.
As for the EEC IV, provided the Cal Edit program has the EGR PID identified, then switching it off should have exactly the same result  ;)
In short, yes switching it off within the ECU stops the lean condition  ;)
Cheers Dave
Offline 3 door 4x4
Re: EGR system
« Reply #15 on: August 28, 2013, 18:41:50 PM »
With the EGR disconnected, mine made 166 BHP at the wheels (4x4) - assume 25% loss in 4x4 drivetrain - transfer box was low on oil as was the front diff and the brakes were binding a little - that's 221 BHP at the flywheel. Had BOB cams, Vectra injectors, K&N and a custom exhaust.
With the EGR connected it  was more torquey and felt a lot more lively. Especially mid range. EGR isn't used at wide open throttle so that makes sense!
Sent from my iPad using Tapatalk HD
Re: EGR system
« Reply #16 on: August 28, 2013, 20:29:00 PM »
Real live experience.
I also found that the fuel consumption was less with the EGR connected.
From Dave2302
As for the EEC IV, provided the Cal Edit program has the EGR PID identified, then switching it off should have exactly the same result  Wink
It can be turned off with the tweecer and caledit.
