Author Topic: Hello from Finland!  (Read 134411 times)
Re: Hello from Finland!
« Reply #120 on: April 10, 2014, 11:50:32 AM »
Why don't you build your own engine mounts and use poly bushings?
Its gives you much more freedom to position the engine the way you want.
Offline capri71
  • Safari 6.1.2 Safari 6.1.2
« Reply #121 on: April 10, 2014, 15:27:01 PM »
Im modifying the mounting points on the crossmember and i have some new 2.8 rubber bushes I'm using for now.
Offline puuhapete
  • Sierra and Raby Castle -03
  • Mac OS X 10.8.5 Mac OS X 10.8.5
  • Safari 6.0.5 Safari 6.0.5
« Reply #122 on: April 14, 2014, 21:13:52 PM »
I fits original mounting to right side engine. Easy fits, but left side
difficult.it.
Offline capri71
  • Safari 6.1.3 Safari 6.1.3
« Reply #123 on: April 15, 2014, 01:28:29 AM »
seems that by rotating the mount like that you shift the weight behind the mount. I prefer to modify the crossmember so everything stays inline on the vertical plane - engine half way point, mounting points and crossmember mounting points, all in line. I could be wrong but it seems they make them this way so I will too. How does the other mounting look?
Don't worry, i will start my project this week and post so you can tell me i'm doing it wrong too  :thumbsup: ;)
Offline capri71
« Reply #124 on: April 15, 2014, 23:18:36 PM »
ok i get what you have done now (cheers Ade) - top job :thumbsup:
Offline puuhapete
« Reply #125 on: April 16, 2014, 19:16:39 PM »
Thank thanks, I do not understand what you tell everything but I will try very hard.  ;D
Now i making you passenger side mounting and look this now. Welding MIG and it seem to little bad but maybe it´s all right.
 down side better.
« Reply #126 on: April 16, 2014, 20:49:57 PM »
Maybe you should pre heat the aluminum before welding or use more current. The thicker the aluminum the more heat you need to get started and to keep the weld flowing.  The big problem with aluminum is that the heat displaces much more than with iron or steel where the heat stays more centered towards the weld.
I would clean the weld of the mount in the first picture and weld it again.
Offline puuhapete
  • MS Internet Explorer 7.0 MS Internet Explorer 7.0
« Reply #127 on: April 17, 2014, 05:24:20 AM »
Maybe....etc
Yes, you are right but i think it works this case well. The car is made ​​for driving, not the show.  ;)
« Reply #128 on: April 17, 2014, 07:36:09 AM »
I am not talking how beautiful you can weld or how nice you weld looks.
The engine mount has to support a lot of weight. You don't want a weld that's weak. The weld on the first picture looks very weak to me.
Offline capri71
« Reply #129 on: April 17, 2014, 10:11:47 AM »
If the arm was steel and the welding was steel i would say strong enough - never gonna break but this cast aluminium and a dissimilar alloy mig wire. Better safe than sorry for the sake of another half an hour work ;)
Offline puuhapete
« Reply #130 on: April 17, 2014, 21:12:44 PM »
You're right guys, you can never be too sure.
Believe me, it is strong enough. You can then laugh at me when it will be resolved and a violation of an engine.  ;D
Offline puuhapete
« Reply #131 on: April 19, 2014, 11:35:51 AM »
I look new ecu and Dta s80 pro able to adjust 2 intake cam.
Anybody know any other ECU to do the same? MegaSquirt option is closed.
« Reply #132 on: April 19, 2014, 12:05:02 PM »
Whats wrong with the megasquirt?
The ms 3.0 and 3.57 with ms3x daughter board can control the VVT similar to the Dta s80 pro. http://msextra.com/doc/ms3/vvt.html
Offline puuhapete
« Reply #133 on: April 19, 2014, 12:15:44 PM »
because, i asked price this mega systems and cost ms3+ms3x only +1000€ and Dta  is about same price. :P
« Reply #134 on: April 19, 2014, 12:26:02 PM »
I payed for the ms3.57+ms3x+ loom and a connector for the ms3x card, 860 euro including tax and shipping. I got mine from diyautotune.com.
Offline puuhapete
« Reply #135 on: April 19, 2014, 12:32:09 PM »
Good price. Do you need to make your own mods if you want vanos?
« Reply #136 on: April 19, 2014, 19:51:00 PM »
I don't use the VVT or vanos as my engine doesn't have that.
But how to wire it up and configure is described on the link I provided you.
Bimmer guys have there vanos working with ms3.
Offline capri71
« Reply #137 on: April 19, 2014, 20:13:29 PM »
I'm using Emerald K6 for mine. I have it confirmed by Dave Walker that it can run the VVT and variable intake no problem. The y have a map for mine which probably be a good base map for yours. I'm going to get mine rolling road mapped but i know of a guy who bought the emerald with the map preinstalled and is more than happy with how it runs his Jag Duratec
Offline puuhapete
« Reply #138 on: April 19, 2014, 20:57:04 PM »
Intresting. You know can Emerald K6 driver straightly jag coils?
Offline capri71
« Reply #139 on: April 19, 2014, 22:51:13 PM »
yep, got 6 ignition drivers - you can use a coil pack or individual like on jag
Offline turboshed
  • Linux Linux
  • Safari 4.0 Safari 4.0
« Reply #140 on: April 21, 2014, 22:20:33 PM »
you need a cam sensor and wire up injectors for sequential but as capri71 says  k6 has 6 ignition drivers
Offline puuhapete
« Reply #141 on: May 02, 2014, 13:47:00 PM »
Down intake waterline modifications Fwd->Rwd. Drilling,cutting and TIG welding pipe in-and outside.
Upper intake is in the works.
D.I.Y intake from 50mm pipes->
and again I thinking next step..
Offline Heath Robinson
« Reply #142 on: May 02, 2014, 14:33:56 PM »
That looks great. Like a ram's horns.
Offline puuhapete
« Reply #143 on: May 02, 2014, 15:36:03 PM »
Thank you! I hope he just as hard. = D
Offline capri71
« Reply #144 on: May 02, 2014, 21:25:54 PM »
Nice ;)
edit - was wondering where you been… now we know ;D
Offline puuhapete
  • Windows Windows
« Reply #145 on: May 03, 2014, 06:23:38 AM »
Nice ;)
Thanks,
Yes, My home now the garage. Two cars,  ST200 engine swap and this.
Offline puuhapete
  • Safari 7.0 Safari 7.0
« Reply #146 on: May 17, 2014, 16:23:13 PM »
I find 53dz my garages.
Laser cutting start ring gear
And 53dz input.
Jag v6 s-type start +special ring
Gearbow up side to engine. One bolt good place.
And modify mountings
Gearbox mounting kit.
Offline capri71
« Reply #147 on: May 18, 2014, 09:21:08 AM »
Although i'm sure it fine, I would have got it water jet cut Pete
that aside everything looks sweet mate :thumbsup:
Offline puuhapete
  • Windows Windows
« Reply #148 on: May 18, 2014, 13:45:52 PM »
Thanks!
Laser cut company is three mails for my works and you know. ;)
Offline capri71
« Reply #149 on: May 18, 2014, 14:33:38 PM »
I doubt it will be a problem since its only a starter ring. Other alternative would have been to cut the ring they weld to the flex plate for auto tranny for that engine… but its done anyway :thumbsup:
Is your diff ratio similar to the BMW that box came from?
I'm using the jag box because my diff is almost the same ratio as the Jaguar diff 3.09 vs 3.06 - practically the same. gear calculator predicted 62 mph in 2nd and 155mph in 5th and 66mph at 3000rpm. My car is at least 600kg lighter though so should get there a lot quicker than the Jag and easily rev out in all gears. No overdrive or 6th gear like you but I don't generally cruise at 155mph ;)
Still wondering about flywheels and clutches though… want a light, single mass. Might use a mondeo ST200 one.
