Author Topic: few questions on a bob 2.9 v6  (Read 9547 times)
Offline clyde1800
« on: November 23, 2012, 19:49:28 PM »
ive got a 2.0 twinky cozzy rep and bought a bob engine loom and auto gearbox
the loom is cut  :o wasnt to pleased to see this and didnt realise this until i had it home
so i bought a boa engine bay loom and i was just wondering will my bob engine harness mate onto this or do i need a boa engine harness?
and also will my ecu work without the pat's system with this loom?
Re: few questions on a bob 2.9 v6
« Reply #1 on: November 23, 2012, 20:15:07 PM »
Hello mate where is the loom cut ? Any pics .
Bob ecu needs the pats working with the key, most if they don't have it all seem to go Boa ecu etc. I'm not really that up on them as I run aftermarket on mine but someone on here will help out.
Offline clyde1800
« Reply #2 on: November 24, 2012, 00:24:24 AM »
I've heard of aftermarket looms. Somebody told me they could get one made up for £200? Is this right enough?
I'll be at the shed tomorrow I've the loom spread across the floor and I've worked out a fair bit of it. The engine harness is ok then on around to the engine bay loom is not to bad really. It continues on to the relay box (box with a lot of plugs into the back of it) then one of the plugs I think from what I can judge goes on to the fuse box. Although some of the wires from this are cut. I'm not sure if this will effect the pats system?
Then there are the rest of the looms from the car. Lighting radio speaker wires indicators brake light switch etc. I've ruled these out. I may if I could find a diagram study the loom and solder the parts I need together again and dispose of unnessary wires out of the loom and try and lighten it. Could anyone tell me where I could get this info?
I'll post pictures tomorrow. Thanks for any help or posts
« Reply #3 on: November 24, 2012, 08:30:00 AM »
Your best going for a BOA ecu, BOA engine loom from a single fusebox car and an engine harness from the BOA.
My website has details of the single fusebox car's engine loom multiplugs.
« Reply #4 on: November 24, 2012, 08:51:10 AM »
TT,
The link below the avatar doesn't work and i need to register to read more...
in google docs:
https://docs.google.com/open?id=0BwnJzcrpCiIlN2U2MTFhYjItYTBiYS00NTNjLTkxN2QtNjAxZDg3MGY3YzRm
Offline clyde1800
« Reply #5 on: December 02, 2012, 11:58:47 AM »
hi i think im going to just opt for the boa loom because the bob loom is missing alot of boxes etc   :'(
ive got the boa engine bay loom already  now i just need the ecu and engine harness
does anyone know will i still achieve 210bhp with the boa loom?
« Reply #6 on: December 02, 2012, 19:22:33 PM »
You need a rpm window switch to operate the VIS if you use a boa loom.
« Reply #7 on: December 02, 2012, 21:41:50 PM »
I run mine with the vis locked closed on the BOA ecu. It made 220bhp at the flywheel.
« Reply #8 on: December 03, 2012, 08:07:35 AM »
But you lose alot of torque in the midrange by keeping the vis closed.
http://www.fordpower.org.uk/forum2/index.php/topic,9586.0.html
« Reply #9 on: December 03, 2012, 10:11:43 AM »
Yes you would but as Paul says you loose torque/power in other area's if the VIS don't work as it should.
Offline clyde1800
« Reply #10 on: December 03, 2012, 18:31:31 PM »
you will have to explain to me what the vis  is?
im not a total numpty i just have never heard of this
and can anybody help me come a cross a engine harness and ecu?
i would like to keep the engine and all its torque as it should although using the bob loom has numerous issues
it will be extremely difficult to keep tidy in and around the engine bay
i have plug ends there but no boxes to go onto them
will my loom work after getting wet?
and the one i have is cut  (will get pics loaded asap)
« Reply #11 on: December 03, 2012, 19:36:53 PM »
Did you read the topic in the link?
Offline clyde1800
« Reply #12 on: December 04, 2012, 07:00:33 AM »
 Didn't see that sorry. But very well explained :).  How do I resolve this? I have no pipes etc lol what can I buy to do away with this system? Like I mean what are all the different options?  How many window switches are there to choose from? Still needing a boa engine harness and ecu. Can anybody help?
« Reply #13 on: December 06, 2012, 21:54:45 PM »
plots for a fixed vis valve.
2 runs with valve closed and one run with the valve open.
Offline clyde1800
« Reply #14 on: July 07, 2013, 10:36:22 AM »
Hi folks.  Recently came across a boa loom  ;D I started last night t strip down the engine and saw the looms over
I took the inlet off and injector rail to expose the loom removed it and fitted the boa.
My problem. Mow is it seems. Will have t extend my throttle position sensor wire?.
Next problem I have is to d with all the vacuum pipes in and around the engine. What d. Need? And what can. I do away with? I will try my best to get pictures uploaded tomorrow as I'm off work for my holidays
« Reply #15 on: July 07, 2013, 18:49:55 PM »
You have to extend the tps wire, but that's not a difficult job.
You only need vacuum for the brakes, the egr and for the vis.
Offline clyde1800
« Reply #16 on: July 11, 2013, 22:25:57 PM »
Ok through my build a bit more now to change the gearbox to manual what do I need to put in the hole where the slicker shaft goes? I know it's a bearing of some sort but to order It i would like to know exactly which one? I also would like to know what all vacuums I need to block?
I guessed the injector wiring because the numbers were not on them but they're handy enough changed if they're wrong
And I need a throttle cable which cable should I go for?
« Reply #17 on: July 11, 2013, 23:11:14 PM »
I used the BOB cable cut and a new end crimped on for the throttle.
You need a spigot bearing for the xr4x4 or any v6 manual. Think the pinto one will also go in.
Offline clyde1800
« Reply #18 on: July 13, 2013, 12:13:01 PM »
Thank you I need t get this ordered before I go any further. Believe it or not the bob engine harness I have is for the bin. The plastic on the wire has gone hard and brittle and the wire is exposed
« Reply #19 on: July 13, 2013, 18:38:52 PM »
Very common with the bob looms.
