Author Topic: Hello from Finland!  (Read 159567 times)
Offline puuhapete
  • Sierra and Raby Castle -03
  • Windows Windows
  • MS Internet Explorer 10.0 MS Internet Explorer 10.0
Re: Hello from Finland!
« Reply #150 on: May 18, 2014, 17:36:01 PM »
I doubt it will be a problem since its only a starter ring. Other alternative would have been to cut the ring they weld to the flex plate for auto tranny for that engine… but its done anyway :thumbsup:
Is your diff ratio similar to the BMW that box came from?
No but zf 6gear ratio 0.82 is fine my 3.73 diff. ;)
Offline capri71
  • Mac OS X 10.7.5 Mac OS X 10.7.5
  • Safari 6.1.3 Safari 6.1.3
« Reply #151 on: May 18, 2014, 19:26:31 PM »
what was the diff ratio on the BMW?
Offline puuhapete
  • Safari 7.0 Safari 7.0
« Reply #152 on: May 21, 2014, 15:48:03 PM »
I dont member Bmw diff ratio. ;) maybe 3.06?
Engine and gearbox adapter is this.
The center of the checkpoint that.
Offline capri71
« Reply #153 on: May 21, 2014, 20:25:48 PM »
Er, the bit in the middle was to check alignment? and you'l cut it away? or am i being a thick as the plate you made it from? ;D
Offline puuhapete
  • Windows Windows
« Reply #154 on: May 22, 2014, 10:42:46 AM »
Yes, i cut then. No comments seconds question's.  ;D
Offline puuhapete
  • Mac OS X 10.8.5 Mac OS X 10.8.5
  • Safari 6.0.5 Safari 6.0.5
« Reply #155 on: May 31, 2014, 10:34:26 AM »
I  welding to TIG the passenger side mounting. Is it any good?  ;)
and the mounting location on the engine.
Lowering engine about 30mm. it is better now in the intake manifold and the gearbox angle
Next, lift the package in the engine room, and build mounts
Offline capri71
« Reply #156 on: May 31, 2014, 15:53:01 PM »
Pete, I think you are rushing to get this done for the summer. This Sierra/cyclone build isn't simple. I think you should slow down, let it be done when it is done and make it so that you don't have to ask us "is it ok?"
i think the sump looks ok… its just the mount that bothers me a bit!
I am really interested in following this and know you can do it properly if you weren't setting deadlines to get it done - keep on keeping on bro ;)
Offline puuhapete
« Reply #157 on: June 01, 2014, 08:15:12 AM »
No, I did not come to ask you that whether it is ok. I'll do it this way and everyone can actually do better. ugh. :mellow:
Some do, others are considering doing so, and the third is talking about it.
Offline puuhapete
« Reply #158 on: June 01, 2014, 08:23:11 AM »
At all events, but I installed the engine in place. A tight fit was.
Next time,next feeling.
Offline capri71
« Reply #159 on: June 01, 2014, 13:41:46 PM »
You say this
Then this
but whatever ;)
Offline puuhapete
« Reply #160 on: June 02, 2014, 22:19:06 PM »
I looked a little turbos places. I think that they will remain in it.
Offline puuhapete
« Reply #161 on: June 28, 2014, 05:58:22 AM »
Engine and gearbox mounting now.
Exhaust welding and ready to start painting now.
Downpipe right hand side:
Milled intake blank
Bye, I will return again someday.
Offline puuhapete
  • MS Internet Explorer 7.0 MS Internet Explorer 7.0
« Reply #162 on: July 02, 2014, 07:28:43 AM »
Tig welding training session in progress. See it now, then show today.
Cheers
Pete
  • Safari 6.0 Safari 6.0
« Reply #163 on: July 07, 2014, 19:49:27 PM »
Your really cracking on with this Pete  :2tu: there is a lot to do to get one of these in a Sierra.
Keep the updates coming  :thumbsup:
Offline puuhapete
  • Mac OS X 10.6.8 Mac OS X 10.6.8
  • Safari 5.1.9 Safari 5.1.9
« Reply #164 on: July 12, 2014, 07:39:35 AM »
Thanks. Maybe?  ;D
I making intake again. step by step, slowly but uncertainly.
Pressure plate cable piece.
Welding school again.
End is ready
Offline puuhapete
« Reply #165 on: July 24, 2014, 21:29:00 PM »
Little up go to start. I painting and welding again. Summer is soon offer and Sierra no`t run.  :'(
Offline puuhapete
« Reply #166 on: July 28, 2014, 12:12:38 PM »
And engine and gearbox look today this.
Offline Heath Robinson
« Reply #167 on: August 22, 2014, 09:37:30 AM »
That's a good looking lump! Good luck getting it into the car.
Offline puuhapete
« Reply #168 on: August 29, 2014, 16:18:10 PM »
Thanks!
And today first start and engine run fine idle. Video is much.
Offline puuhapete
  • Safari 6.1.6 Safari 6.1.6
« Reply #169 on: September 04, 2014, 21:21:56 PM »
Diy aluminium curve small degrees.
last day pipes
Offline puuhapete
« Reply #170 on: September 06, 2014, 10:47:03 AM »
Long time this project but this it is now.  :laugh:
« Reply #171 on: September 14, 2014, 20:10:50 PM »
Well done Pete, that's looking very nice and sounds great to :2tu: you must be over the moon with it.
Maybe a trip to the uk next year ?
Offline puuhapete
« Reply #172 on: September 15, 2014, 17:54:01 PM »
Thanks Lemon-Ade!
How knows, where we are next summer. But this curve today. Only boost 0,37 bar (turbo housing, plenum little low this)  Stock injectors, but fuelpressure is 4.0bar and FSE regulator 1.7X
No monster, but torque start fine.
Next bigger injectors, maybe RE85 fuel and boost.
« Reply #173 on: September 15, 2014, 19:02:05 PM »
The engine response very good to even low boost.
Offline puuhapete
  • Windows Windows
  • Mozilla compatible Mozilla compatible
« Reply #174 on: September 15, 2014, 20:39:53 PM »
Yes, old 4.3 engine 2000rpm about 175nm and this is 285nm.  :mellow:
  • Chrome 33.0.1750.154 Chrome 33.0.1750.154
« Reply #175 on: September 21, 2014, 23:11:54 PM »
Oh wow Pete I will have to come back to this & read it all as I am just off to bed.
So glad you ditched that old 4.0L Cologne & gone for this.
I don't know anyone who has achieved great results with that old boat anchor but this new engine you have.
WOW! Awesome job mate.  :2tu:
« Reply #176 on: September 23, 2014, 09:24:38 AM »
Just gone through that lot from where I last saw it.
You have done a great job Pete, your machine work is always very good & I just know you're going to have better luck with this engine.
What turbo's have you gone for? & I guess there will be some internal mods planned soon.
However this engine will almost certainly out perform your old one as it is!  :thumbsup:
Offline puuhapete
  • Windows Windows
« Reply #177 on: October 05, 2014, 10:13:53 AM »
Thanks Dave!
Now turbos is again china garret. Godspeed marked now ;D
Turbine ar .63
55.79/63.36mm
Comp. ar .60
54.28/71.32mm
Offline puuhapete
« Reply #178 on: October 12, 2014, 11:03:11 AM »
The classic images today. Year 1991 and the previous owner of this car image. He has also shot a lot of pictures of the rally in the world and his name is Kari Nääntäinen. Wheels is 16" RS 7-spoke and Good Year 195x50 tyres.
And I take same place phtoo yesterday. 2014.
and park hall whit good lights to pics.
Pete
« Reply #179 on: October 12, 2014, 22:48:25 PM »
Them pictures only make it look like the cars had a respray & some different wheels.
However we all know different! :o  :2tu:
It's been a well loved car!
Turbo's are big T3's then, wish you would go for something more modern mate but they should work O.K.
