Author Topic: map clamping  (Read 1701 times)
Offline sierra3dr
map clamping
« on: October 08, 2012, 12:04:16 PM »
Is it just a myth?
 installing a Zener Diode between the Signal and Signal Return Line so the engine controller will only see Map voltage to a certain point.
A Zener Diode is a Voltage Regulator.
When voltage reaches the threshold that the diode id designed for it closes allowing the excess current back to ground.
In this case the Zener Diode is 2 Watts/4.3 Volts so the Map Sensor will never see voltage above 4.3 Volts which is equal to approx. 11 lbs of boost.
Using a Zener Diode will prevent overboost shutdown BUT the controller will not add fuel above 11 lbs of boost so if you go over that you will be LEAN.
Re: map clamping
« Reply #1 on: October 08, 2012, 12:41:03 PM »
Ford map sensor work on frequency, not on voltage.
If you want a map sensor for boost, buy one thats ment for boost applications.
And what happens if the engine goes lean at boost? Most ecu, programmed for N/A applications arent programmed for boost, so it will not compensated for boost anyhow.
Re: map clamping
« Reply #2 on: October 10, 2012, 21:33:14 PM »
I have done it with TT kits to push them closer to the overboost limit but as Paul says it is a bodge make no mistake.
Can be usefull but you are taking a big risk!
Offline JFB Tech
Re: map clamping
« Reply #3 on: October 10, 2012, 22:03:23 PM »
TT used MAP clamping on their DOHC turbo kit but only to stop the ECU seeing the boost signal and going into LOS.  The DOHC uses a frequency output and the frequency was limited by a pcb wired into the MAP sensor wiring.  On this setup, the additional fuelling was controlled by a DCU, firing an additional injector.
In general, clamping the MAP sensor signal should only be used to prevent an OEM n/asp ECU seeing boost while additional fuelling/ignition advance would need to be handled by a piggy back device.
The best method, obviously would be do remap the ECU to cope with boost, or if not possible, ditch the n/asp management and fit something suitable for boost.
Drive it like you mean it!
IPB Image
