Author Topic: ECU Types  (Read 1977 times)
Offline Matt
  • 96' scorpio 24v, Edge Sport
ECU Types
« on: August 27, 2012, 15:23:35 PM »
hello all
im after a bit of info, im looking at getting a RS2000 ECU to run a scorpio lump but could do with one without pats
ive found 1 that has DADS code on it but dont know if its pats enabled
cheers
Re: ECU Types
« Reply #1 on: August 27, 2012, 19:44:21 PM »
There is more than one ECU code for the MK6 RS2000, the AFAR and they both have pats.
You need the red key, the transponder and the pats modul that belongs to the ecu.
The 1AGB code is for the RS2000 mk5 (a), has no pats.
Offline Matt
Re: ECU Types
« Reply #2 on: August 28, 2012, 09:07:21 AM »
cheers Paul
ill look out for a 1AGB
matt :)
