Author Topic: Need help identifying parts  (Read 2603 times)
Offline Matt
  • 96' scorpio 24v, Edge Sport
« on: August 20, 2011, 17:09:10 PM »
Hey all
Got a Job lot of ford bits for older fords im led to believe but need help identifing the parts using the finis or part numbers
HOSE - FORD FINIS - 1311122  motor craft number 1S41 8B274BF
HOSE - MOTOR CRAFT 98AB 8B273 DG (TURBO FLEXIBLE)
FUEL HOSE - FORD FINIS 1118671
BELT - MOTOR CRAFT - YS6E-6C301-BB   6K1687
BELT - MOTOR CRAFT - 2S6E-6C301-DB     6K1019
BELT - MOTOR CRAFT - 2S6E-6C301-CB     5K690
CLUTCH CABLE - FORD FINIS 1024093 PART No 93BB 9C799 JH
AIR FILTER - MOTOR CRAFT 94FF 9601 AA
AIR FILTER - MOTOR CRAFT 89BF 9601 AA
SEAL - FORD FINIS 1198063 PART No XS4Q-9G605-AH
REFLECTOR - PART No 2N11-515C0-A
RUBBER MOUNT - PART No 86AB-6038-BB
BEARING THINK FORD FINIS IS 6635542 PART No 92VB-4826-CA
TRANS DAMPENER FORD FINIS 6500028 PART No 898T-7L-195 AB
Hope some one can help
Re: Need help identifying parts
« Reply #1 on: August 20, 2011, 21:00:36 PM »
Hey all
Focus 98 - 05 1.8 Diesel
Think you have the wrong codes for the belts mate.
Mondeo 93 - 96 1.8 Diesel
Fiesta 94 - 96 Diesel
1.3 HCS Fiesta/Escort
1.8 Diesel Lynx Crank Cover
REFLECTOR - PART No 2N11-515C0-A = Wrong Code????
Fiesta/Escort 1.6 Diesel Gearbox mount
Wrong code???
You should know this one! Off the back of a MT-75 gearbox!
Offline Matt
« Reply #2 on: August 21, 2011, 15:52:43 PM »
Cheers Dave
Wrong code???
only other number i have regarding this item is IMP0617  :unsure: they look to be prop shaft centre bearings, i have 4 brand new if i can work out what they are off lol
With the Trans Dampener, should these be fitted to a RWD box? ive never seen one fitted on the scorps and dont have one on mine, do they make any noticeable difference?
Matt  :laugh:
« Reply #3 on: August 21, 2011, 22:27:10 PM »
I can tell by the part number it's off a transit but which one I don't know as it's not been avaiable for a while!
If someone has an old Microcat it might show it on that as mine is newish.
That particular damper is off a 2.0L
They must help otherwise they wouldn't bother but I don't know to be honest.
