I will be painting this to match the colour code when done, I'm not too sure about the amp shelf yet, I might us holographic vinyl as in past builds cause it's great for bouncing the light from the U.F.O. kit which will be going back in. In the previous builds they've all had full covers over them so all you could hear from the back when covered was the bass from the subs. I don't get vibration from the body work because I've put sound deadening on everything, inside the doors, inside the quarter panels, the tyre well, the back panel & from the bulkhead to the back panel. The fuel cut off switch has been moved from the tyre well to under the back seat so the rear battery tray could be welded in. The engine is fitted with 2 Alternators, 1 for the car, 1 for the rear battery. This will power all auxilliarys such as the 2 UFO kits, the sound system, the external 12volt jump lead connection for the tow bar which I custom built through the bumper to tow my jetski if they ever get finished. The tow bar is designed to come off leaving no trace of it ever being there.
[ You are not allowed to view attachments ] [ You are not allowed to view attachments ]
