Author Topic: New range of aftermarket parts in the pipeline.......  (Read 3676 times)
« on: May 26, 2011, 16:22:59 PM »
Very excited to annouce I`ve just secured a motorfactor account with one of the leading distributors of aftermarket car parts in the UK.......currently waiting for my online ordering system to be setup then I can start listing/selling products on the webstore.
Some of the brands I`ll be able to offer will be.........
Euroflow cats and exhausts
SKF & Sachs clutches and flywheels
FAI/Sachs/Boge suspension components
Auto-X/Mintex discs, pads, and shoes
Torque-X batteries, HT leads and alternators
Bosch lambda senors, plugs and wipers
Kerr Nelson engine management components
Granville engine fluids
Cooper Fiaam filters
Will also be have access to a Nippart components and a whole range of other smaller engine parts ie original Jubilee clips, thermostats, hoses etc
Parts listed above will be next day delivery by courier
I`ve been looking at the stock and they stock alot of the Ford range, so going to start off specialising in just Fords parts to begin with and then expand into other vehicle makes.
As always FordPower members will get a discount on orders, I should be able to set-up a discount code for everyone to use on the webstore once the parts go live.
Will update post with delivery prices and examples of some part costs once I know I can start ordering. ;D
Re: New range of aftermarket parts in the pipeline.......
« Reply #1 on: May 26, 2011, 17:48:29 PM »
Well done mate.
Sounds like things are going well.
« Reply #2 on: May 27, 2011, 11:18:33 AM »
 ;D all the hard work I`ve put in over the last 2 years are showing dividends and things are ticking over nicely at the moment.
blue oval 24v
« Reply #3 on: July 22, 2011, 21:34:54 PM »
nice one mate hope you do well ;)
« Reply #4 on: July 22, 2011, 22:26:54 PM »
Hi Leebay, can you get bearings off your SKF supplier? If so I need the one on the 24v oil pump drive gear in the cap or bung (old dizzy location) on the top rear of the engine.
Cheers Ade
« Reply #5 on: July 30, 2011, 17:45:42 PM »
BTTT  ;D
« Reply #6 on: July 31, 2011, 17:36:07 PM »
Sorry mate didnt see this. Yeah can get SKF bearings not sure whether the supplier is limited to just wheel bearings or not.
Have you got a part no. or size you require?
« Reply #7 on: July 31, 2011, 19:11:12 PM »
Hi Leebay
I'm not home today but I will measure it tomorrow night.
Cheers ade
« Reply #8 on: August 01, 2011, 19:34:30 PM »
Hi Leebay
No dimensions on it, but appears to be 28mm outer dia with a 12mm centre dia and 8mm thick.
Nsk 6001 on it.
Cheers Ade
« Reply #9 on: August 01, 2011, 20:16:34 PM »
its a very common bearing, its also used in skate boards, bikes, well, in a lot off purposes.
first hit on ebay:
http://www.ebay.co.uk/itm/6001-2RS-NSK-Rubber-Sealed-Bearing-60012RS-12x28x8mm-/320672640043
« Reply #10 on: August 02, 2011, 12:32:10 PM »
Cheers Paul  :angel:
