Author Topic: Exhaust manifold  (Read 2598 times)
Offline deltamal
Exhaust manifold
« on: May 23, 2011, 17:51:38 PM »
Does anyone manufacture after-market tubular exhaust manifolds for the 2.9 Cologne? Iv'e had a look around the internet and can't find any...
Re: Exhaust manifold
« Reply #1 on: May 23, 2011, 20:59:42 PM »
how many do you need?
http://www.summitracing.com/search/Department/Exhaust/Part-Type/Headers/Make/FORD/Engine-Size/2-9L-177/?Ns=Rank%7cAsc
these are meant for ranger's and bronco's, but can be adapted for other cars.
« Reply #2 on: May 23, 2011, 21:40:02 PM »
Has anybody tried fitting these to a 24v?
You'd have to change the flanges but would be a good option as long as the primaries etc are any good?
Offline deltamal
« Reply #3 on: May 23, 2011, 23:22:41 PM »
Thanks for info! do you know if Summit have an outlet in this country? as shipping cost can be expensive, they look ideal, would not be a problem to tweak them....
« Reply #4 on: May 24, 2011, 08:13:43 AM »
they do not have a store outsite the U.S. you can order directly at summit and pay with your creditcard or paypal.
there are company's that order for you at summit, but thats $$$$. its beter to do it your self. shipping cost are high at the moment, but its still cheaper than picking the parts up in the states  ;D. the dollar is still high.
if the spacing off the exhaust ports is the same for the 12v and 24v, you could used them on the 24v after you changed the flange. the primaries are 38 mm, collector diameter is 50.8 mm for the pacesetters and 41 mm/63.5 mm for the JBA.
« Reply #5 on: May 26, 2011, 21:43:42 PM »
Well the 24v uses the Cologne base so I think the port spacing is the same.
I'm very tempted but space is a bit tight.
