Author Topic: 24v turbo 4x4 MK3 escort  (Read 69382 times)
Offline robrs2
  • Firefox 12.0 Firefox 12.0
Re: 24v turbo 4x4 MK3 escort
« Reply #60 on: February 28, 2014, 21:08:11 PM »
Looks good . What are the rear uprights based on.
Offline v6gerry
  • Mozilla compatible Mozilla compatible
« Reply #61 on: February 28, 2014, 21:46:45 PM »
Hi they were made by LEDA to suit the car I spoke to them they told me what measurements they needed so done that and they made them , they are very much like the front coilovers which are xr4x4 .
  • Safari 6.0 Safari 6.0
« Reply #62 on: February 28, 2014, 22:02:35 PM »
That's a proper job you made of the shell  :thumbsup: looks great Gerry
Offline v6gerry
  • Chrome 33.0.1750.117 Chrome 33.0.1750.117
« Reply #63 on: March 01, 2014, 10:38:05 AM »
Thanks ade every one seems to cut all the floor and wings out these days , which i think is a lot more work . my pistons are being made in germany and will  have a REF number which people can order through Tom .is your getting more bits added to it looking more like a engine ? ;)
« Reply #64 on: March 01, 2014, 14:36:26 PM »
Do you have a spare block Gerry or are you rebuilding the old one?
Offline v6gerry
« Reply #65 on: March 01, 2014, 19:14:16 PM »
what do you mean by the spark block the pack which the 6 HT leads come out of ??
« Reply #66 on: March 01, 2014, 19:16:24 PM »
No I mean a spare engine block.....
Offline v6gerry
« Reply #67 on: March 01, 2014, 20:06:43 PM »
SORRY I miss read your post !! yes I had a bob engine which I broke up , so using that block with my boa crank and rods ,
  • Chrome 33.0.1750.146 Chrome 33.0.1750.146
« Reply #68 on: March 09, 2014, 21:45:17 PM »
Great work on the shell mate!  :2tu:
Yeah the graph tells the story.
You can see by the boost plot & torque curve the wastegate has control by 2600rpm. This means you have reached the max turbine flow by about 2600rpm. The wastegate can usually give you another 15% at least or so on top of that depending on it's size then when you hit that limit the back pressure is going to really ramp up & start to cause reverse flow in the combustion chamber as you have more exhaust pressure than intake killing power.
The drop in power reduces exhaust flow but you still have so much back pressure due to higher revs that the wastegate is forced open. The two combined causes the boost drop in your case because we know the compressor can flow enough air for that power.
A restricted exhaust flow creates high EGT's combined with the slightly lean mapping on that graph that again causes high EGT's is what killed your piston due to detention caused by extreme EGT's.
You have stuck a turbine section intended for a 2.0L engine onto a 2.9L.
The bleed valve reduces the boost pushing on the actuator so it can withstand the back pressure for longer.
However you will see the same happening again just higher up the rev range or if you run more boost.
Also the turbo will never make the same power on the 2.9 engine it can on the YB, the turbine will limit it just like the washer's fitted to restricted mopeds!
Offline v6gerry
« Reply #69 on: March 11, 2014, 18:20:51 PM »
Thanks Dave it does make some sence to me but don,t really under stand it to be honest , like all things I will talk to tom about it ,
thanks for your input Dave .
gerry
Offline turboshed
  • Assumption is the mother of all fuck ups!!
  • Linux Linux
  • Safari 4.0 Safari 4.0
« Reply #70 on: March 12, 2014, 22:57:39 PM »
The only way to see if your turbo is too small (which it is) would be too monitor exhaust pressure pre-turbine and also compressor side.compare the 2 over the power map and you should see a peak of back pressure and the fall off bhp
xr4x4 twin dinky turbo, emerald k3 management,302bhp and 400ftlbs@21 psi
« Reply #71 on: March 12, 2014, 23:09:27 PM »
Yeah like as Gray says once you have 4 bits of info in graph form it will all make complete sense.
You can see exactly what is happening & how they affect each other.
Boost + exhaust back pressure pre turbo + EGT at input of turbine + torque plot
As a general rule (except VNT's etc) if the turbo hits a bar of boost before half max rev's it's too small.
But again it depends what you're looking for. If your happy that's what matter's.
Offline v6gerry
« Reply #72 on: March 14, 2014, 19:09:48 PM »
thanks for all your input guys but its getting toooooooo deep for me to understand (sorry guys ) will post up when engine is dyno but it still might have the T3 on as im doing a new plenum for it and prob won't be ready in time , so will change things then cos the STD plenum we all no will restriced the engine .
cheers gerry
Offline v6gerry
« Reply #73 on: April 21, 2014, 21:49:41 PM »
small update been doing a bit while waiting for engine to be done , as it gets a little warm inside of car on long journeys , so lined tunnel back to gear stick hole with heat reflective matting , took me most of a day with making cardboard templates and edging each piece all round with the foil tape  , it turned out good well pleased hope it works , next job is to alter inner wing for bigger turbo as the T3 is about 15mm off inner wing ,
Offline v6gerry
« Reply #74 on: May 07, 2014, 21:44:57 PM »
Got my parts back from powder coating , and spraying , got to wet sand paint of the cosworth badges to show alloy . no news as yet on engine still waiting for piston to arrive  :rolleyes:
Offline capri71
  • Mac OS X 10.7.5 Mac OS X 10.7.5
  • Safari 6.1.3 Safari 6.1.3
« Reply #75 on: May 07, 2014, 21:52:02 PM »
like the blue… looks mint :mellow:
Offline v6gerry
« Reply #76 on: May 07, 2014, 22:06:48 PM »
Cheers bud its same blue as the car ,
Offline capri71
« Reply #77 on: May 07, 2014, 22:49:30 PM »
Its very nice as blues go. Ive decided on blue for my covers too but not sure if i fancy a flat crinkle or a nice shiny metallic. VHT do a fake anodise system with a silver base and coloured lacquers that caught my eye too. Yours looks proper moody and should stand the heat no problem when you think how bonnets get heat cycled. Can't wait to see them on the engine :thumbsup:
« Reply #78 on: May 08, 2014, 15:20:22 PM »
Looking really nice there mate  :thumbsup: its the time to do it all while you wait. The pistons must be any day now?
Offline mk2 cossie
  • Windows Vista/Server 2008 Windows Vista/Server 2008
  • Chrome 34.0.1847.131 Chrome 34.0.1847.131
« Reply #79 on: May 08, 2014, 17:11:28 PM »
those parts look very good indeed Gerry  :mellow:
How long have you had to wait for the pistons so far?
It's bloody annoying when something like that holds up the build  :rolleyes:
Offline v6gerry
« Reply #80 on: May 08, 2014, 17:21:34 PM »
thanks its only car paint 2k but solvent not water bourn paint , will look loads better then the flaking paint that was on them was corroided as well . time will tell with the heat !!!!
Offline v6gerry
« Reply #81 on: May 08, 2014, 17:31:17 PM »
[/quote
Cheers mate yep get the little bits out the way , I've altered the inner wing ready for a bigger turbo  ;D  , I did think the wait would be longer then what tom quoted but  it out of my hands , got to phone tom about something see if he has heard anything , won't make the pod on 1 june now sadly . :'( Don't want him to rush it now , be ready when its done ,
Offline v6gerry
« Reply #82 on: May 08, 2014, 17:43:58 PM »
Hi took engine up there end of jan , Tom got piston in which he thought would be ok for it , but wasn't happy with them so back they went , decided to get them spec made got drawing sign off and about 3/4 weeks ago they got in touch with him and wanted something confirmed so sent the drawings back to him to be ok , he said they are now   being made as we speak so won't be long ,
that's about all I no , at least I no it will be ok when I pick it up , and he will dyno it so back into car, get  MOT and play  :2tu: ;D.
Hows your going now you got the emerald on it ?
Offline mk2 cossie
« Reply #83 on: May 09, 2014, 22:24:45 PM »
It's geting there slowly, just need to get to track and road still  :rolleyes:
But finding the time with it as my only form of transport is a bit of a tricky one  :-X
Offline v6gerry
« Reply #84 on: May 09, 2014, 22:44:26 PM »
at least your using it  ;) all things like this you have to make time for it , as all we seem to do is chase our tails LOL !!! spoke to Tom ( engine builder ) today and he had just spoken to them about pistons , as he is waiting for 6 sets of piston to arrive as his customers are on his back , mainly race engine and racing is well under way now . he said he should have all 6 sets within 2weeks , and we will prob change the T3 compressor to a T4 to pump more air into the V6  ;D so won't be long now !
« Reply #85 on: May 11, 2014, 10:19:04 AM »
T4 FTW  :2tu: Tom is more than a builder he does the whole package, a very well respected tuner, dyno operator with great customer service.
He supplied and built an engine recently in a rs500 for someone I know and he is very pleased with Tom  :thumbsup:
Offline v6gerry
« Reply #86 on: May 11, 2014, 16:01:53 PM »
yes mate he no his stuff for a yb people say its Tom or Harvey gibbs  !! he dose it all mate the only stress I've got is I want my engine back ! but that is out of mine and Tom's hands at mo , tom said they said within the next to weeks  :2tu: I've altered my inner wing ready for the T4 its only about 1inch bigger in o/a dia !i'll post a pic up when I've painted it back in with inner wing . how is yours going mate ?
Offline v6gerry
« Reply #87 on: June 20, 2014, 22:31:21 PM »
Hi all they here the long awaited pistons for my new low comp 24v engine . Tom said they are good for 800 bhp !!!! won't be long now might be on the dyno this time next  :  . [/UR
[URL=http://s1042.photobucket.com/user/gartrac/media/DSC_9602.jpg.html]
Offline mk2 cossie
  • Chrome 35.0.1916.153 Chrome 35.0.1916.153
« Reply #88 on: June 21, 2014, 00:21:01 AM »
Very nice indeed Gerry  ;D
Shame to hide them inside the engine though  :o
Just realised the heat proof mat pics further up, looks very good fitment wise. Was it all a swine to fit?
Offline v6gerry
« Reply #89 on: June 21, 2014, 09:49:31 AM »
mm yes shame they wont be seen  :'( the matting took me all day I made cardboard templates then trimmed the matting in and sealed the edges with foil tape , should help to keep cockpit cooler  ;D
