Author Topic: Quick help please  (Read 2031 times)
Offline scud
Quick help please
« on: October 11, 2009, 14:56:53 PM »
I cant seem to locate the fuel pump relay on my 91,H xr4x4  and im in the middle of wiring up the 24v please can somone help identify it a bit quick  cheers
Offline v6gerry
Quick help please
« Reply #1 on: October 11, 2009, 15:39:38 PM »
Quote from: scud
Hi its the purpul one behind the glove box on the earlyer 4b quite sure it the same on all the 4b.
V6gerry
Offline scud
Quick help please
« Reply #2 on: October 11, 2009, 16:20:41 PM »
no mate those are the abs on my car ive already established that
Offline littlegems4x4
Quick help please
« Reply #3 on: October 11, 2009, 17:32:59 PM »
It's one of the small brown ones in the fusebox, can't think which one right now though, although I think there are only 2
« Last Edit: October 11, 2009, 17:33:27 PM by littlegems4x4 »
samol
Quick help please
« Reply #4 on: October 11, 2009, 22:56:47 PM »
Agree with "littlegems4x4" it is a small brown relay in the fuse board, and if my memory is working its the one in the middle furthest away from the bulkhead. Cheers Ray
Quick help please
« Reply #5 on: October 12, 2009, 00:49:54 AM »
Well on a 89 car it's the pink one in the main box.
Quick help please
« Reply #6 on: October 12, 2009, 13:01:36 PM »
Mines an 89 G reg Dave and it's deffo the brown one, typical Ford always changing their minds
samol
Quick help please
« Reply #7 on: October 12, 2009, 16:48:59 PM »
Hi Dave, mine is a 89/90, (G Reg), to and the pinky one, (with the bit of duct tape) is for the air con, definately the brown, (between the blue and white), is for the fuel pump. Cheers Ray
[attachment=2917:fuse_box_int.JPG][/attachment]
« Last Edit: October 16, 2009, 23:58:54 PM by samol »
Offline scud
Quick help please
« Reply #8 on: October 12, 2009, 18:59:19 PM »
cheers ray that should solve it , now, to start another ive got a problem thread
Quick help please
« Reply #9 on: October 16, 2009, 10:38:01 AM »
O.K
To clear this up.
The pinky one is known as the fuel pump relay but all it does is prime the system.
Remove it & it won't prime but will still run once the engine turns over.
The brown one controls more than just the pump but if you remove it, it will kill the pump & most of the engine electrics to.
Well thats how I remember it.
Offline scud
Quick help please
« Reply #10 on: October 16, 2009, 23:52:23 PM »
Quote from: Dave
O.K
To clear this up.
ta mate ill start poking it again tomorrow
