Author Topic: 24V BOA engine Gasket set......  (Read 2097 times)
24vdan
« Reply #1 on: May 06, 2009, 21:55:15 PM »
I can help with cam cover gaskets, £55 a pair including postage. I have the exhaust gaskets as well.  The other tricky gasket is the timing chest item but a BOB gasket is available for that.  Don't use a 12v gasket, it could cause major problems.
Make sure to plug the open oilway near the bottom of the blade if it's 'open' and not covered by the gasket you use.
« Last Edit: May 06, 2009, 22:03:19 PM by Mikey'J »
