• Welcome, Guest. Please login.
November 19, 2019, 13:00:30 PM
My Mk1 24V XR4i
Started by V6 POWER JUNKIE, March 02, 2009, 21:36:28 PM
V6 POWER JUNKIE
March 02, 2009, 21:36:28 PM Last Edit: September 22, 2010, 14:00:23 PM by V6 POWER JUNKIE
If It Ain't Going Sideways I Don't Care!!
Leebay
Shiney    Lovely 4i mate.
LDS Engineering.co.uk
Cylinder head Repairs/skimming, Engine|Brake|Suspension|Service components, Number/show plates & Custom stickers.
mouldytbags
March 03, 2009, 17:07:41 PM #2 Last Edit: March 03, 2009, 17:35:50 PM by mouldytbags
what was your previous results mate? mine made 206bhp but now has bob cams vec injectors so who knows what it is now.
fook sake should have read more
was that result done with the 3 branch maniflods and ported heads?
V6 POWER JUNKIE
March 03, 2009, 17:40:18 PM #3 Last Edit: March 03, 2009, 17:46:24 PM by V6 POWER JUNKIE
Hi Mouldy.
Here's the full story.
After the 24V conv' on standard headers & 2.8 xzorsts from downpipes back, no air con she ran 195HP.
Took off the Viscous, put in a set of NGK Double Platinums & had the 6 Branch made she ran     225HP.
Now she got Elec' Power Steering Column, (Manual Rack wiv a 2.8 Quaife, so less drag again),
Bob's, Vec Inj, & Ported Heads, but still not finished yet, so hopefully Next Wk i'll have another RR &
then i'll know the Outcome, i'll post the new print out then.
Gaf.
mouldytbags
i had 5bhp more drag than your print out.next time im gonna try new diff g/box oil and see what happens.
V6 POWER JUNKIE
Incase u want to compare anymore, it's running a Type 9 Box, & a Limmy diff, But the crown wheel
& pinion is a 3.3 - (out of a 1.6 sierra estate), not a 3.6, i find wiv a 3.6 diff it's hard to get any grip.
v6gerry
Quote from: V6 POWER JUNKIE
Hi where did you get your manifolds made ?
V6gerry
V6 POWER JUNKIE
Kezza
Looks nice, good to see a mk1
bahamacharger
V6 POWER JUNKIE
SteveS
What kind of 4spd box do you use? Is it a type5 maybe?
V6 POWER JUNKIE
5 Speed Type 9 M8.
Don't know how long it's gonna last with this result though lol
Leebay
 Nice! Best budget for another gearbox in the near future then
V6 POWER JUNKIE
lol, yeh me thinks, some more mapping 2day & got more
V6 POWER JUNKIE
bitterend
If you don't mind me asking, who made the exhaust manifolds, and how much were they?
I need to get a pair made up, but they cant follow the standard route.
V6 POWER JUNKIE
April 12, 2010, 00:45:13 AM #18 Last Edit: April 12, 2010, 00:46:52 AM by V6 POWER JUNKIE
No probs, £970 http://www.pro-speedexhausts.com/]http://www.pro-speedexhausts.com/
for the lot, but he charges £250 each Mani, £500 Downpipes Back
Gaf.
smashed
well lad fine set up you got there is there much work involved in fitting them throttle bodys they obviously made a great difference.
V6 POWER JUNKIE
Quote from: smashedwell lad fine set up you got there is there much work involved in fitting them throttle bodys they obviously made a great difference.
Not at all, i bought the kit from Jenveys themselves & they came complete with Inlet Manifold, Boddies,
Trumpets & all the linkage already made up.
It was a bit af a fiddle, to fiddle with the linkage to get em right & a bitch to balance em all the same,
but once tha was done pretty straight forward, had to make a throttle cable bracket, air temp bracket &
drill & tap the rear of the manifold  x 2 for brakes.
But pretty much bolt off & on
Gaf.
SteveS
Quote from: V6 POWER JUNKIE5 Speed Type 9 M8.
I saw in the undercar pic that it's a t9 but on the video you only shifted up to 4th i guess. And this is what i did not understand.
V6 POWER JUNKIE
Yeh M8, All Power Run's Done In 4th Only
littlegems4x4
Looking good there Gaf, and you had a great result power wise. Can't wait to see those TBs in the flesh
V6 POWER JUNKIE
Cheers Toby, They Georgeous M8 & Very Shiney, Wait till U hear Em though
blue oval 24v
nice one mate have been on youtube to see this going :ph34r:thinking off going the same way with my boa any tip's?? lol.do you think if i got the (bent) stacks would the bonnet close?? thanks for any info mate
V6 POWER JUNKIE
Sure, smaller stacks would work, any thing particular just ask mate ;-)
Lemon-Ade
Saw you and heard you on Sunday Gaf  ;) I have some short clips on my phone, what rpm was it just before the bridge where Olaf filmed from? It sounded awesome  :wacko:
Ade
V6 POWER JUNKIE
Hi mate, i change at 6650, thas when the power starts to drop off  ;D
blue oval 24v
hi gaf. are you still running on the bob cam's?? and what sort of fuling are you running still on the vec injectors and is there anymore mod's that you have done to the engine??have you lost any low down power?sorry about asking all these but would like to know befor i shell out £1500 on the tb's thanks again gaf
blue oval 24v
