Author Topic: Project 24v Cortina is back on!  (Read 1988 times)
Offline CortinaPhil
« on: February 09, 2009, 01:49:42 AM »
After a period where I thought I was going to have to scrap my plans to build a stripped out 24v Mk3 Cortina, I think I have worked out a way to carry on with it
To recap, the engine is going to be a (standard at first) BOA lump mated to a Type 9 gearbox using V6 bellhousing a 2.8 Capper flywheel and clutch.  As I need to get the car running as soon as possible, I am going to keep the standard 1.6 Cortina rear end (I have a 3.44 axle awaiting rebuild).
I need to get the car running (and ideally MOT'd) as soon as possbile and as cheaply as possible... but I want the car to be safe and will spend money where it needs it.  These leads on to the first of a few questions...
1  Brakes - I thought of going the Granny or Princess callipers/Capri disks route but, for the cost of the callipers, I'm wondering if I might be able to get a new kit from somewhere.  The cheapest I saw on Burtons was just over £300... is there anywhere cheaper?
2 Suspension - can anyone recommend which springs and shocks I should use at the front?  I'm looking for a ride height just slightly lower than standard (too many spped bumps!)
3 Electrics - I was going to have a crack at this myself with zero experience... am I mad!?!  (I only want minimal gauges and have removed EVERYTHING else!)
Any help much appreciated!
« Reply #1 on: February 09, 2009, 04:08:22 AM »
if you want it cheap, go for the scorpio brakes, they are more powerfull than the old setup.
Offline CortinaPhil
« Reply #2 on: February 09, 2009, 04:20:53 AM »
Quote from: capri v8 driver
Thanks for your reply.  Do you know if the Scorpio brakes will fit straight onto a Cortina hub without any machining?
« Reply #3 on: February 09, 2009, 14:20:07 PM »
i made a bracket for my setup. only machining i did was turn down the hubs, so the disk would fit.
someone whit a lathe can do that.
here you can see how its done: http://www.zyworld.com/CAPRISPORT/1_brakes.htm]http://www.zyworld.com/CAPRISPORT/1_brakes.htm
