similar to mine, i'm on a cebora 130amp, it will use the 1.0 although the liner is only ment for .8, trouble is they can't work for long on the thicker wire and mine cut out and died for a while, was ok the day after, I've found using the 0.6 you get a more reliable welder and an adequate weld,
