Author Topic: whoops, had a small off!  (Read 2146 times)
haggis
« on: October 20, 2008, 15:56:34 PM »
first gravel rally in the sierra. we were 16th overall out of 31 at service until the car misted up on stage 4 and i pretty much drove off the road.
no real damage done. was my codrivers first rally so had to get a pic of him with the stranded car!
check out how wet it was!
[url]http://img238.imageshack.us/my.php?image=dsc003471nt6.jpg[/img][url]http://g.imageshack.us/thpix.php]
« Reply #1 on: October 20, 2008, 18:46:16 PM »
At least it was just a ditch rather than a tree.
Offline jamie-turbo2
« Reply #2 on: October 22, 2008, 02:32:54 AM »
glad to see yous were both ok and car looks fine.
  heard there were a few off`s , glad i stayed in bed going by the weather down there.
   are you doing the galloway hills ?
  jamie
haggis
« Reply #3 on: October 22, 2008, 23:48:29 PM »
had a good look about the car and it needs a bit o work
sill punched in, floor a bit bent but nothing major
exhaust gubbed and car will need skidded (plates under the floor for protection)
should be ready for the galloway hills but i hear its a car breaker!
« Reply #4 on: October 23, 2008, 01:54:21 AM »
I wouldnt say its a car breaker, its more a test of how well the cars built !!!
It will rattle everything to death so back up is a must on many parts, inside of switches will fail , so have space ciruit for fuel pump, and run two . Mkae sure every nut and bolt is either using a spring washer or lock nut , on suspension nuts and bolts drill holes and wire them , makes it easy to check if somthings loose.
Under car protection is a must , so fully skid and plate, and exhaust lets most people down as it takes a beating in the woods.
im sure you now what your doing anyway and you will be fine on the hills.
   jamie
