Author Topic: 24v relays  (Read 1662 times)
brad24v
24v relays
« on: October 15, 2008, 17:41:12 PM »
wondering which relay i need from the granada 24v (BOA) for the fuel injector relay and fuel pump relay? what colour are they and where are they located on the car? the car is on a M reg before the frog face model, any help would be great guys thanks.
24v relays
« Reply #1 on: October 16, 2008, 08:55:12 AM »
red is the system relay, yellow the fuel pump relay. they can be found in the fuse box in the engine bay, near the window or whit older models, under the dash, behind the glove box.
« Last Edit: October 17, 2008, 08:13:09 AM by capri v8 driver »
coco
24v relays
« Reply #2 on: October 16, 2008, 21:39:02 PM »
Quote from: capri v8 driver
These will be the two i should be using in my capri 24v conversion then is it ???  Mine's not a fuel injection capri to start off with !!
24v relays
« Reply #3 on: October 17, 2008, 08:11:58 AM »
yes.
brad24v
24v relays
« Reply #4 on: October 17, 2008, 13:16:52 PM »
yes.
thanks mate!
