Author Topic: Rust treatments  (Read 2101 times)
Offline Mik
Rust treatments
« on: September 01, 2008, 17:20:17 PM »
As above, what works best on experience. Been using Jenolite liquid but its not as effective as I'd like and its pi##ing me off.
Any suggestions.
Mik.
Rust treatments
« Reply #1 on: September 01, 2008, 17:29:47 PM »
i don't like any of them, shot blast and or cut out the cancer IMO the only way.
Offline Mik
Rust treatments
« Reply #2 on: September 01, 2008, 18:05:58 PM »
Its just for the small repairs where its not benificial/cost effective to rip out an arch for a rust blister. Larger rot always gets replaced with fresh steel, that is the only 100% way to get rid. Also, surface rust doesn't always need the panel replacing if its only light. Usually gets cut back with grinder cup but the "infection" is still there.
Anyone tried Dinitrol?
Mik
Rust treatments
« Reply #3 on: September 01, 2008, 20:00:34 PM »
I`ve been using Vactan on both my fiesta and escort for small bits of surface rust.
Rust treatments
« Reply #4 on: September 01, 2008, 22:57:29 PM »
Ive used ferrozinc. you have to get the metal shiny - this just stops it coming back which i think is what you want.
Rust treatments
« Reply #5 on: September 02, 2008, 09:30:21 AM »
In short if you can not sand the rust off back to proper metal or there is a hole it needs to be cut out & replaced with fresh steel.
Don't matter if 50p size or a whole wing.
Just not worth the risk of it coming back.
But saying that if you can not weld then do what your budget allows.
Rust treatments
« Reply #6 on: September 02, 2008, 09:55:56 AM »
yep.
Only way IMO is small shot blasting gun for tiny blisters then mig up.
Bigger stuff needs cuting right back and repair patches fabricating.
Offline sierra3dr
Rust treatments
« Reply #7 on: September 06, 2008, 05:37:49 AM »
Quote from: Mik
Any suggestions.
Mik.
That Jenolite is wank from what I remember,it comes in a gel form,right? I live in Middleton and I can pop round to your place if you like,and see what you think of Fertan http://www.fertan.co.uk/]click here
text me on 07530 602733
regards
Paul
« Last Edit: September 06, 2008, 06:16:49 AM by sierra3dr »
Offline Mik
Rust treatments
« Reply #8 on: September 06, 2008, 11:31:18 AM »
The Jenolite I've got is a liquid but it comes in gel form too. Just repaired 2 rear wheel arches on a mates Puma. All went well but has now reacted. you'd swear that I'd wiped it dowm with water prior to spraying. Seriously, seriously pi**ed me off. Now got to do it all over again.
Will give you a ring later mate, Cheers
Mik.
