Author Topic: sierra wide arches  (Read 4195 times)
Offline turboshed
sierra wide arches
« on: August 14, 2008, 20:57:57 PM »
thought about this for a while now and finally got the grinder out,these are some escort forest arches which I cut down,going to get some bigger wheels next year so hence why they sit a bit more out than they should   but they worked a treat i lowered the car on the coil overs and it handle better than expected round brands the other day
« Last Edit: August 15, 2008, 14:26:53 PM by turboshed »
Offline Mik
sierra wide arches
« Reply #1 on: August 14, 2008, 21:19:58 PM »
looking good, surprisingly. Will look bitchin once you've filled them up a little.
It's one of the few things on sierra's thats naff, even wide wheels  don't fill the arches.
Mik.
Offline turboshed
sierra wide arches
« Reply #2 on: August 14, 2008, 21:29:42 PM »
those wheels are 8 1/2 inch 17's with 235 45 tyres on i reckon i need 9 inch with slighlty more offset
sierra wide arches
« Reply #3 on: August 14, 2008, 22:25:44 PM »
why not adapt a thunder saloon kit
yeah i know of one,,,,
Offline turboshed
sierra wide arches
« Reply #4 on: August 14, 2008, 22:34:55 PM »
was thinking of the thunder kit but those escort arches only cost a fraction of the thunder kit,plus i have used some roadsweeper seals to take up the slack between wings and arches,and those where free!I really hate spending too much time in bodywork,just bosh it on and job done.
do the thunder kit rear arches allow you to lower the car,i have removed quite alot of inner wing so i still have loads of room to drop the car further if i wanted
« Last Edit: August 14, 2008, 22:36:41 PM by turboshed »
sierra wide arches
« Reply #5 on: August 14, 2008, 22:44:43 PM »
take the outer part of the inner wing out and you go as low as ya want
Offline turboshed
sierra wide arches
« Reply #6 on: August 15, 2008, 06:36:11 AM »
i cut slots in the rear outer and inner and bent them all up so i have loads of room under those arches,just need to tidy it all up as the mot guys may not like it
sierra wide arches
« Reply #7 on: August 15, 2008, 08:10:08 AM »
Don't call them wide arches, look more like girlie ones to me
If they do the job m8 thats all that matters
sierra wide arches
« Reply #8 on: August 15, 2008, 18:43:49 PM »
hi rob
i hope i dont get drawn to the dark side and fit my set
but
eerrmm would be nice
tone
sierra wide arches
« Reply #9 on: August 16, 2008, 00:01:37 AM »
Err I kinda like that Gray.
Will have to look at it in the flesh.
Offline turboshed
sierra wide arches
« Reply #10 on: August 20, 2008, 12:27:54 PM »
think i could of made them fit alot better,but it's the first time i've fitted any and probably i'm the only person to fit them,i am going to redo the nearside as i did that in the dark in a hurry trying to get it done for brands hatch the next day.
 rang my mot place up and explained that i had " cut the arches off",they said "it would be fine" than i said "no listen, i have cut the arches right off , the rear outer skin is no longer attached to the inner wing"..................."oh"he said....."well if you cover it in gaffa tape then i cant see it can i"........"goodman!" i replied.expanding foam and gaffa tape here i come
« Last Edit: August 20, 2008, 12:28:39 PM by turboshed »
sierra wide arches
« Reply #11 on: August 20, 2008, 13:18:46 PM »
Sorry mate thats not for me at all. i assume you 'need' the width for traction? you painting the bonnet up to match not leaving it black?
Expanding foam is the future. bloody messy stuff like isn't it!
vinnyvangough
sierra wide arches
« Reply #12 on: August 20, 2008, 16:47:35 PM »
I do really like that mate.
topcat
sierra wide arches
« Reply #13 on: August 21, 2008, 23:42:42 PM »
whats, wrong with them if he likes them that fine by ME,
« Last Edit: August 21, 2008, 23:43:37 PM by topcat »
Rob01
sierra wide arches
« Reply #14 on: September 03, 2008, 21:34:11 PM »
Don't look half bad :D , hope you gonna fill them with some wide ass wheels!
Offline turboshed
sierra wide arches
« Reply #15 on: September 03, 2008, 23:24:55 PM »
believe it or not the wheels in the pic are magnesium 17x8 1/2 inch wide with 235 45's on,i'm looking to get some 9 or 10 inch wide with more offset and slicks on for track.just need to do something with the rear beam to get rid of some camber,may make up a an adjustable rear beam at some point as i need to get the rear lower to get some weight back on it...........or a couple of bags of sand
