Author Topic: How much do 2.8s wobble/move?  (Read 1368 times)
« on: August 01, 2008, 12:08:44 PM »
I'm asking cos of this - http://fordpower.org.uk/forum/index.php?showtopic=5599&hl=]http://fordpower.org.uk/forum/index.php?sh...ic=5599&hl= - mine hardly moves at all at idol but i'm thinking its going to move most when you pull away - the engines too stripped to do that right now to test so i need best/educated guesses. Can you fit thinner, harder rubbers and a spacer on the engine mounts to restrict motion?
« Last Edit: August 01, 2008, 12:12:12 PM by Janspeedcapri »
« Reply #1 on: August 01, 2008, 13:49:10 PM »
Quote from: Janspeedcapri
Cant really say how much movement they have but harder mounts will reduce the movement.......although like I`ve just found out on my xr2i last week when I put some uprated gearbox mounts on (to stop the engine from rocking and hitting the strut brace) The harder the mounts the less they absorb vibrations. I`ve had to go back to some O.E. mounts from a diesel as they`re abit harder than standard fiesta ones because EVERYTHING in the car vibrated on idle, was horrible to drive as well, really jerky.
If you swap to some uprated ones its worth doing abit of research into what mounts are available and try to speak to someone those has those uprated mounts mate.
« Reply #2 on: August 01, 2008, 14:52:50 PM »
  noted.... I just looked at the alternator, and its closer to the metalwork than my turbo is    if that hasn't been smaking the turbo should be fine and dandy - however the proof will be when i run it and if i need stiffer mounts I'll see whats available first - CHEERS BUD
Offline grimbo
    • http://www.projectford.co.uk
« Reply #3 on: August 02, 2008, 07:19:13 AM »
you could always try a small shock absorber on one side just to null it a bit like on the mk1-2 mini and the other small bl cars 1100, maxi ect
grimbo
24v Capri for ever I hope
Hummmmm!!!! super glue me thinks
Ford 100e Anglia manumatic
[url]http://www.mybannermaker.com/]IPB Image
« Reply #4 on: August 02, 2008, 10:51:55 AM »
Quote from: grimbo
...and most large bmw - I was actualy thinking of that as another soluution myself as it goes  but i think it'll be fine anyway - i think now half inch is plenty space - I was surprised to see how close the alternator was to the body
