Author Topic: wastegate psi rating  (Read 1878 times)
« on: July 19, 2008, 22:11:51 PM »
What psi should the wastegate open for a single turbo 2.8 aiming at 1 bar (12psi) boost? Ive found a 38mm wastegate which I'm told is the right size but i can get it with springs for 4, 6, 8 and 12 psi - what should i go for to alow 12 psi boost on the compressor side? I was guessing 6 maybe? rather play safe i spose and swapping it up isn't that hard if its too soft right?
« Reply #1 on: July 20, 2008, 21:21:24 PM »
A 12 psi spring gives 12 psi. I you want to run less boost but be able to turn it up then go for a lowwer rates one and run a boost controller. Boost controllers bleed the air off from the wastegate and allow it to give a higher boost level.
« Reply #2 on: July 20, 2008, 23:27:10 PM »
Cheers Rob
« Reply #3 on: July 21, 2008, 12:24:05 PM »
and 1bar is 14.5psi.
« Reply #4 on: July 21, 2008, 15:21:32 PM »
ooooooooooooh
« Reply #5 on: July 21, 2008, 17:10:08 PM »
2.5 psi makes a big difference mate.... trust me.
« Reply #6 on: July 21, 2008, 19:38:03 PM »
no i meant "oh" as in
