Author Topic: AC Pipe disconecting  (Read 2911 times)
« on: July 12, 2008, 20:26:48 PM »
How do you get appart the AC pipe conectors??
« Reply #1 on: July 12, 2008, 22:11:38 PM »
Quote from: TwinTurbo
With a special tool    if I can will get a pic of them tomorrow, its basicly a thin plastic tube.
« Reply #3 on: July 12, 2008, 22:59:53 PM »
you can use 5 small screwdrivers and lots of paitence.... but please video it cause i'd love to watch  , some times you can use the transit clips still on the hose from when they were fitted, but Taps is right the plastic tube is so simple! get one.
Ian
« Reply #4 on: July 12, 2008, 23:20:15 PM »
From where??
« Reply #5 on: July 12, 2008, 23:26:18 PM »
I've always used the 5 screwdriver technique.... taps will get you the link tommorow i think...
Those seally ones look ok mate.
Ian
« Reply #6 on: July 13, 2008, 07:49:04 AM »
A piece of pipe cut length ways down the side. Use a small screw driver to move the spring in the fitting back the push the cut pipe over the a/c pipe and into the sprung bit. Then pull appart.
I used some 10 or 15mm copper pipe, you could also used the plastic stuff
Offline simes
« Reply #7 on: July 13, 2008, 23:29:55 PM »
Cheers mate would be a great help, Have seen some sealey ones that are quite cheep but don't know if they will do the job.
http://www.sealey.co.uk/PLPageBuilder.asp?pageindex=1&gotonode=DoProductSearch&method=mProductSearch&IndividualTypeID=&productdescription=vs0454&fulltextsearch=&category=0&cmdGo=Go%21]http://www.sealey.co.uk/PLPageBuilder.asp?...amp;cmdGo=Go%21
Those are the same tools I have and they work a treat both on the granada 24v and the sierra 2.9
