Author Topic: Who running oil coolers?  (Read 2765 times)
« on: June 22, 2008, 12:22:33 PM »
Seen its not too exspensive if youve got room, and since i'm fitting a bigger turbo...might be wise to plan on it now?? or not??
scratt
« Reply #1 on: June 22, 2008, 13:01:21 PM »
Quote from: Janspeedcapri
yes mate they do help alot,i do rallying & the temperature on mine was running around 120 degrees,fitted a 235mm x19 row in the front,it now runs at 90 degrees which should be around normal operating temperature.if it runs too hot the oil looses its lubricating properties.hope this helps.
Transit RS
« Reply #2 on: June 22, 2008, 17:17:24 PM »
Quote from: scratt
did that need the oil pump uprating?
Offline turboshed
« Reply #3 on: June 22, 2008, 21:56:30 PM »
fitting an oil cooler will not need pump upgrades,but i do reccomend fitting a thermostat as running cold oil can be as bad as running hot oil.i need to fit one to mine as cruising on the motorway oil temps are down but it works really well on track.
I have seen oil coolers fitted in front of rads and intercoolers which is a bad move due.i have fitted my 19 row cooler where the screenwash bottle was,then cut a hole in the bumper and put a scoop in so its very efficient at speed
« Reply #4 on: June 23, 2008, 20:35:45 PM »
Quote from: turboshed
excellent    since i have a rad and an intercooler in front of the engine, i was thinking of 2 diddy oil rads either side - this how they did the intercoolers on an audi i had...worked well using up the voids infront of the wheels and gives practical purpose to 2 nice vent/grill/scoops either side of the valance  ...only downside was that the slightest front end ding meant serious damage....nice car ...it was
Glad some one raised the pump question - and glad its not an issue
Thanks all
« Reply #5 on: June 24, 2008, 11:55:44 AM »
would you leave the Standard Water/oil coiler on or bin that in favour of a air/oil cooler.
Ian
« Reply #6 on: June 24, 2008, 23:06:57 PM »
Quote from: IansSaph
Ian
i hadn't about it but seeing as you mentiuon it and ive now had at look at the blighter, i dunno how to get rid of it or stop it working. BUT i reckon it could be a good idea if it would drop the coolant temps???
i suppose your oil needs cooling more the faster you move, which suits oil rads realy - if you are crawling in slow moving trafic, you don't need much oil cooling but you need all the coolant efficiency you can get so it sounds like a plan if anyone can point in the right direction with doing it???
« Reply #7 on: June 25, 2008, 12:03:26 PM »
Personally i'd unbolt the filter arm and remove the water-oil cooler and put the sandwich plate in its place for the air-oil cooler then either joint the water pipes together or run a new pipe from the thermostat to the heater matrix.
Thats what i plane to do... unless anyone says different.
ian
« Reply #8 on: June 25, 2008, 22:53:08 PM »
which bits which? Them fancy names mean bugger all to a chancer with a halfrauds socket set like me
