Author Topic: Fancy I4 pullys  (Read 1835 times)
Fancy I4 pullys
« on: June 21, 2008, 09:36:40 AM »
« Last Edit: June 21, 2008, 09:37:33 AM by Marty »
Fancy I4 pullys
« Reply #1 on: June 21, 2008, 15:15:03 PM »
hello Marty.
increasing the diameter off the pully's could give you some extra hp. but that also give you a slower rotation off the pully's. so less cooling and the dynamo work's give's less power.
making the pully's lighter could be making 1 or 2 hp, but thats something you need to test on a dyno, to see a result.
Fancy I4 pullys
« Reply #2 on: June 21, 2008, 15:44:03 PM »
I can think of better ways of spending £120
Fancy I4 pullys
« Reply #3 on: June 21, 2008, 15:53:58 PM »
These pulleys.... a carbon fibre prop, racing flywheel, alloy hubs, no engine fan or alternator...then  you might see a difference lol
Fancy I4 pullys
« Reply #4 on: June 21, 2008, 16:03:41 PM »
Make a prop out of bog-roll tubes
Call it 'cardboard-fibre'
samol
Fancy I4 pullys
« Reply #5 on: June 21, 2008, 23:16:24 PM »
I think that on the I4 the crankshaft pully is also the vibration damper, so fitting a lighter one "could" affect the smooth running of the engine. Ray
madasahatter
Fancy I4 pullys
« Reply #6 on: June 21, 2008, 23:19:53 PM »
Quote from: Marty
Depends if she is worth it?????
