Author Topic: Granada bits in sierra  (Read 2162 times)
Rob01
« on: June 09, 2008, 20:46:43 PM »
not sure if this is the right place , but say if i bought a Granada 2.9 12v and wanted to fit the engine into my sierra 1.6 what other parts would I need to source?
Thanks!
« Reply #1 on: June 09, 2008, 21:33:27 PM »
If you brought a complete granada nothing really
Rob01
« Reply #2 on: June 09, 2008, 21:39:17 PM »
well , its a complete car that I'm loking at the now , what about the fuel tank and bits on the sierra , its a single point innj 1.6 cvh btw
ta
« Reply #3 on: June 09, 2008, 21:47:48 PM »
Tank should be ok , fuel pump in it might need upgrading but could be fine will look up what pressures they run compaired to the 12V and let ya know
Rob01
« Reply #4 on: June 09, 2008, 21:58:05 PM »
Thanks
but what about the engine mounts
« Reply #5 on: June 09, 2008, 22:09:50 PM »
If there the same fitment as yours use the granny ones, if there not then fit the granny front crossmember
Right
Your 1.6 requires Fuel pump delivery pressure 0f 3 bar min
2.9 requires Fuel pump delivery pressure of 5 bar min
So you current pump might well not be up to the job, you can always swop the granny pump onto your set up, thats providing the granny one is a in tank pump, if its external then your need to change the tank to use the granny pump.
Rob01
« Reply #6 on: June 09, 2008, 22:12:25 PM »
Will an XR4i 2.8 box fit
This is the car
« Reply #7 on: June 09, 2008, 22:32:24 PM »
Rob is that an auto?
Rob01
« Reply #8 on: June 09, 2008, 22:36:53 PM »
yes sadly, will be a manual if i go ahead with the conversion
« Reply #9 on: June 09, 2008, 22:57:19 PM »
Ok, if you go 4i T9 then your need a 2.8 flywheel and clutch to go with it, cheaper way to go then going MT75, either box your need to fit a spigot bearing in the end of the crank.
« Last Edit: June 09, 2008, 22:58:03 PM by Taps »
