Author Topic: air con hose  (Read 4865 times)
jaffa
air con hose
« on: January 02, 2008, 21:10:16 PM »
ive got air con fitted on my 4x4 but since ive fitted a strut brace the air con hose is stretched over the top so i need a longer hose fitting anybody got any ideas?
air con hose
« Reply #1 on: January 02, 2008, 21:21:24 PM »
Have a look at a 24V scorp one
Dont look like it comes out at such an angle as yours.
jaffa
air con hose
« Reply #2 on: January 02, 2008, 22:35:43 PM »
air con hose
« Reply #3 on: January 03, 2008, 07:42:14 AM »
Will it fit? Where it goes into the pump on the 24V is in a differant place IIRC
Are you sure the pipe won't go under the brace?
air con hose
« Reply #4 on: January 03, 2008, 08:52:27 AM »
Quote from: Marty
It would if he used the same brace as yours
air con hose
« Reply #5 on: January 03, 2008, 09:39:54 AM »
Should fit under that
air con hose
« Reply #6 on: January 03, 2008, 09:51:12 AM »
Quote from: Marty
Must admit I've never seen one go over the bar before
xr4x4 mk1
air con hose
« Reply #7 on: January 03, 2008, 10:22:26 AM »
That should go under your bar easily Jaff      It would look a dam site better under than over
« Last Edit: January 03, 2008, 10:23:13 AM by xr4x4 mk1 »
jaffa
air con hose
« Reply #8 on: January 03, 2008, 17:57:25 PM »
Quote from: xr4x4 mk1
tried it mate but the angle it comes out from the bulkhead means you cant push it down to go under the strut brace
air con hose
« Reply #9 on: January 03, 2008, 18:25:02 PM »
The pipe is only alloy, you can bend it
Offline snoopaloopa
air con hose
« Reply #10 on: January 03, 2008, 19:06:30 PM »
Thats not the correct one for  a 2.9  is it?
not sure how that helps you    but i did get to see my motor again without getting cold
air con hose
« Reply #11 on: January 03, 2008, 19:13:59 PM »
Quote from: snoopaloopa
I like those rocker covers
jaffa
air con hose
« Reply #12 on: January 03, 2008, 19:16:04 PM »
yeah it is mate (i think)  plus if it was the same as yours id end up having clearence issues
on the abs like taps is at the moment
Quote from: Marty
if you bend it it will just crack!
and im tryiong to do the job without breaking anything
« Last Edit: January 03, 2008, 19:17:59 PM by jaffa »
air con hose
« Reply #13 on: January 03, 2008, 19:30:35 PM »
I bent the hell out of mine when I fitted the 24V engine, it won't crack
Just apply steady pressure and only bend as much as you need and you won't go wrong. If possible try and bend on the straight and not the bend if possible.
« Last Edit: January 03, 2008, 19:31:01 PM by Marty »
Offline snoopaloopa
air con hose
« Reply #14 on: January 03, 2008, 20:03:44 PM »
Quote from: Marty
wondered if you'd remember mate    there coming off soon to be polished up and fitted on my TT
Jaffa,
if you will mess about with new fangled things like abs then you deserve all you get
on a slighty more serious note, the bloke i got mine from had it fitted onto his 'abs' xr4x4, must have been tight but then if its not touching its ok
« Last Edit: January 03, 2008, 20:04:22 PM by snoopaloopa »
jaffa
air con hose
« Reply #15 on: January 03, 2008, 22:01:21 PM »
Jaffa,
funny the bloke i got mine off had it fitted to an abs 4x4
air con hose
« Reply #16 on: January 03, 2008, 22:12:00 PM »
Totally off subject I know but what make are your strut bars Marty Jaffa and Snoopaloopa
air con hose
« Reply #17 on: January 03, 2008, 22:22:04 PM »
Here's my strut brace... shown fitted to the donor vehicle still along with my polished intake & cam covers.
jaffa
air con hose
« Reply #18 on: January 03, 2008, 22:49:08 PM »
not sure mate there wasnt any markings on mine and ive had it powder coated now
Offline snoopaloopa
air con hose
« Reply #19 on: January 03, 2008, 23:14:13 PM »
'GT Performance' mate
air con hose
« Reply #20 on: January 04, 2008, 07:38:56 AM »
Mine is differant to the other two's
However I no longer have mine
I 'think' it might have been OPM
But the one on my 3dr is 'Wiechers' a German make.
Offline sparkplug
    • http://www.xr4register.com/
air con hose
« Reply #21 on: January 04, 2008, 07:40:17 AM »
Jaffa's is a GT Performance Cosworth item as there 2.9 one would not fit due to hitting the ABS brake fluid bottle. I bought it at Trax and I tried several at the show and this was the best fitting brace I could find. Gengis has a 2.9 brace on his ABS car but has modified the fluid bottle to get it to fit. I sold it to Jaffa as I could not get it to fit with my supercharger setup. When I had it fitted to my car I did not has Air Con so it was not a problem but I can see your problem Jaffa but are you going to keep the Air con?
[url]http://www.xr4register.com/]IPB Image
jaffa
air con hose
« Reply #22 on: January 04, 2008, 18:17:55 PM »
Quote from: sparkplug
not sure yet mate   id like to until i sort out engine
