Author Topic: Quick question on a temp sender  (Read 2814 times)
Chuck W
« on: November 04, 2007, 22:12:07 PM »
Hey folks.
Quick question....  Is the Ford part number E6RY-10884-B available over in the UK?  It is a coolant temperature gauge sender with a "purple" ring around the plug.
It's an oddball that was used on the US XR4Ti (with the 2.3T) and it's unobtanium in the US any more.  I'm guessing the calibration was for a euro-spec application and may be used and available overseas.
Just curious
Chuck
« Reply #1 on: November 05, 2007, 20:25:38 PM »
do you have the ohm range off the sensor?
« Last Edit: November 05, 2007, 20:30:08 PM by capri v8 driver »
Chuck W
« Reply #2 on: November 05, 2007, 20:33:24 PM »
The XR4Ti uses a different sender than the rest of the US 2.3T cars, which is probably due to the different gauge calibration.
« Reply #3 on: November 05, 2007, 20:39:04 PM »
Had a look on mcat and that number dont come up m8
« Reply #4 on: November 05, 2007, 20:59:34 PM »
if i know the range off the sensor, i can measure some temp sensors i have here.
xr4man
« Reply #5 on: November 22, 2007, 02:46:30 AM »
chuck, i used a cosworth temp sender, part number yb0201 on my xr4ti. it is justa  little smaller than the stock sensor so you will need to go to home depot and get an adapter fitting. the sensor is only $4 from cosworth usa and $7 for shipping
