Author Topic: WARNING Shot/Media/Sand Blasting  (Read 10303 times)
« on: May 11, 2007, 22:32:06 PM »
More and more peeps are finding there engines are getting fooked after having parts Blast cleaned, this has mainly been on 24V Plenums and cam covers but could have the same results on any engine.
So be WARNED
This came out of cam covers that had been cleaned through several times before fitting, ended up in the sump and went through the oil pump destroying it
« Last Edit: June 27, 2008, 21:07:08 PM by Taps »
Ticky
« Reply #1 on: September 22, 2007, 09:06:48 AM »
Quote from: Taps
So be WARNED
All engine parts that need cleaning internally like plenums etc should be blasted with the media which is very fine crushed walnut shells. Used in the states a lot but hardly anyone over here has heard of this blasting media. If any particles are left inside the engine they do no damage and get collected in the oil filter quite safely.
Ticky
rallyslag
« Reply #2 on: October 01, 2007, 22:47:15 PM »
used to chuck wallnut shells down jet engines to clean em
LotusCapri
« Reply #3 on: June 07, 2008, 23:04:53 PM »
Hmmm, blasted my shell with iron grit (100kg jblast @75 cfm  ) with the engine in and have been wondering if any has found its way into the intake. I still see a bit in the shower tray every morning after 2 weeks and its still on the cotton buds i clean my ears with
btw - engine concerned is the cologne thats coming out, not the blueprinted Lotus
anyway, you don't grit/shotblast engine parts do you? Chemical hotwashing innit?
« Last Edit: June 07, 2008, 23:13:50 PM by LotusCapri »
Offline Mikey J
« Reply #4 on: June 08, 2008, 09:36:21 AM »
I've started powder coating plenums and cam covers and was shocked at how much crap had got in the plenum.  It took several hours of flushing with a hosepipe before I was happy the sand had been rinsed out fully.  I'm making some blanking plates to seal the plenums in future.
« Reply #5 on: June 09, 2008, 10:28:36 AM »
excellent info and just in time, i've stripped mine for cleaning this weekend, blanks for the plenum is a top idea, i'll make some up my self.
Ian
Offline sierra3dr
  • Chrome 28.0.1500.95 Chrome 28.0.1500.95
Re: WARNING Shot/Media/Sand Blasting
« Reply #6 on: September 11, 2013, 10:28:32 AM »
I looked into walnut shells for health/enviromental reasons,as I prefer not to breathe in the mainstream media.  I did get some,forgot I had it ;D
  • MS Internet Explorer 10.0 MS Internet Explorer 10.0
« Reply #7 on: September 11, 2013, 20:24:54 PM »
You could use salt as a blasting media.
Offline totsy
  • Chrome 38.0.2125.104 Chrome 38.0.2125.104
« Reply #8 on: November 10, 2014, 21:40:56 PM »
I had both my 12v and 24v pleniums and rocker covers done.  I usually clean my engine parts with Mr Muscle oven cleaner cos it gets rid of all the grease and oil.  I was suprised with how much crap came out of the pleniums, then sprayed loads of alloy wheel cleaner in them.  That rinsed out the rest.  Then painted them all.  Powder coated the 12v but the red powdercoat went brown over time.
 [ You are not allowed to view attachments ]
