Author Topic: Clean up Several parts for sale!!!!!  (Read 376 times)
  • Windows 10 Windows 10
  • Chrome 86.0.4240.80 Chrome 86.0.4240.80
« on: October 18, 2020, 14:31:23 PM »
For a classic mustang:
2 speed wiper motor with a interval function.
Asking price for the set: 100 euro.
A bunch of parts for the Ford C4 transmission.
Parts are used but there are also new parts.
Asking price for all the C4 parts: 250 euro.
A9P ecu ’89 til '93 mustang with a AOD automatic but it can be used for a manual. Ecu Pin 30 needs to be connected to earth.
Asking price : 275,- Euro.
8LG ecu for a ’88 mustang with a AOD. It can be used for a manual. Ecu Pin 30 needs to be connected to earth.
Asking price 150 euro.
Both ecu's came from a running car.
Edis 8 module for a ford 8 cylinder with the connector.
asking price 75 euro.
I don't need to explain how rare these ecu's are in Europe and even in the states they are getting rare.
2.9 12v ecu from a ’90 scorpio.
0GHB 2.9 v6 ECU with cats w/o maf for automatic
Asking price 75 euro.
Distributor 2.9 v6 12v
Throttle cable BOA Cosworth 2.9 24v
For a engine swap with a 2.9 24v BOA Cosworth with a automatic you need the throttle cable for the kick down switch.
Asking price 30 euro a piece.
Ford capri mk3 head lights LHD
Asking price 50 euro for the 4.
Fuel line for a holley double pumper.
asking price 25 euro.
Vented Rear disk brake kit for a ’93 thunderbird 2.3 turbo. These kits a used for rear disk conversions with a 8.8 rear axle but if you make you own brackets they can be used for most rear axles.
Disks are 108 mm x4 but you can use other disks.
asking price 200 euro.
I also have a bunch of original Tremec T56 6 speed Dodge Viper parts.
Shim kit for all T56.
Asking price 25 euro.
Reverse gear wheel mainshaft 35t asking price 150 euro
Reverse gear wheel 1 piece counter shaft asking price 50 euro.
3e gear t56 37t asking price 150 euro
5e gear t56 67t asking price 120 euro
6e gear t56 58t asking price 110 euro.
The 5e and 6e gear wheels are for a T56 with a 1 piece countershaft with a single syncro.
1/2 syncr assembly asking price 100 euro.
3/4 syncro assembly asking price 100 euro.
Shift rod gm t56, Shift forks for the reverse and 5/6. asking price 25 euro for the shift rod and 25 euro per fork.
Tremec #51 Front Offset Lever (F-Body & GTO & Cobra & Viper) -
Tremec #93g Rear Offset Lever (F-Body & Cobra & Viper) -
T56 input shaft ford cobra 10 spline for a T56 with a 2.97 1e gear. asking price100 euro.
Z link voor alle T56. asking price 10 euro per 2.
I also have some other small stuff for the T56. These parts are for a original Dodge viper 6 speed gearbox till 2007 unless noted. Some of these parts will fit other T56. I don't need to explain how rare these T56 are in Europe and even in the states these parts are getting hard to find and are very priced. The parts can bought separately or you can make me a offer for all of the T56 parts.
Parts can be shipped if needed. PayPal preferred unless you pick them up.
Timewasters dreamers and people without money, please look further.
