Author Topic: Cossy BOA running lean  (Read 27 times)
Offline Richard Knight
  • Member
  • Hi, I'm new here...
  • Chrome 81.0.4044.138 Chrome 81.0.4044.138
« on: May 20, 2020, 17:06:55 PM »
Hi All,
I have a BOA engine running in a kit car and she seems to be running lean - the egr is removed but all else is normal including ECU. is there a way to richen up the mixture at all?
  • Edge 18.18363 Edge 18.18363
Re: Cossy BOA running lean
« Reply #1 on: May 20, 2020, 19:05:20 PM »
How is the fuel pressure and the lambda values?
And no there isn't much you can do with the stock ecu to make it run richer. Losing the EGR creates a very lean condition in the mid range of the RPM and the ecu cannot compensate for it.  Some people used bigger injectors or upped the fuel pressure but that opens a other box of problems.
The only way to run the engine properly without the EGR is to use aftermarket ECU.
