Author Topic: Wiring a BOA loom in a sapphire  (Read 2504 times)
Offline Kevinmcc2010
  • Member
  • Hi, I'm new here...
« on: April 18, 2015, 20:13:03 PM »
Hi there, I'm putting a 2.9 v6 24v boa engine in my 2.0 dohc sapphire and wanted to know how it's wired and could you use the 2.0 wiring loom and just add wires to it???any help please
Offline ali
  • Member
Re: Wiring a BOA loom in a sapphire
« Reply #1 on: April 26, 2015, 20:38:39 PM »
hey. you will need to remove the 2.0 engine wiring harness and ecu as very little of it would be of any use to the boa loom. you need to strip back your boa loom to just what is needed to run the engine, and then you can connect it to the plugs behind your battery so it looks like a factory loom.
