Author Topic: Sierra coilover spring rate suggestions  (Read 6884 times)
Offline scud
« on: September 21, 2014, 14:55:01 PM »
I'm after some suggestions for spring rate and length for coilovers on my xr4x4 24v(BOA) please, ie what are you using and what for?
For now im keeping the arb and the rubber top mounts,its not a daily drive it will probably be mostly road with occasional track use.
I like a good firm ride but the roads round here can be very poor in places and I don't want to crack the windscreen or my spine if I cant dodge a bad pothole.
cheers Col.
  • Firefox 31.0 Firefox 31.0
Re: Sierra coilover spring rate suggestions
« Reply #1 on: September 22, 2014, 22:06:28 PM »
You will not crack the screen. I have 650lb front and 450lb rears for track use only. Although that seems hard its not to bad. Standard coilovers for road are about 320lb front and 250lb rear.
Offline scud
« Reply #2 on: September 23, 2014, 17:47:22 PM »
thanks rob that's usefull to know,
I don't suppose you know the weight difference between a boa and a 2.9 12v?
I have searched but cant find anything usefull or definite
Offline Heath Robinson
  • Mac OS X 10.6 Mac OS X 10.6
  • Firefox 32.0 Firefox 32.0
« Reply #3 on: September 24, 2014, 10:24:08 AM »
I'll be interested to hear that too, I tried to track down the weights for them the other day, and came up with 3 different figures for the BOA!
Offline scud
« Reply #4 on: September 25, 2014, 19:57:54 PM »
exactly  :unsure:
Offline v6gerry
« Reply #5 on: September 25, 2014, 21:56:05 PM »
A 24v BOA is 205KG with out flywheel there a post under 24v engine section , hope this helps .
Offline scud
« Reply #6 on: September 26, 2014, 21:45:43 PM »
thanks I looked before and never found it  :rolleyes:  so I looked more, still can only find guestimates not much better for the 12v either
best guess so far is  12v 160ish kg  24v 220ish kg
Offline scud
« Reply #7 on: September 28, 2014, 16:05:20 PM »
I was wondering what ride height you guys are running at ? can I get a few measurements from the center of the alloy engine crossmember to the road please
 4b v6s only especially if you consider it lowered but sensible
thanks
« Reply #8 on: September 30, 2014, 22:28:46 PM »
There is a measurement but cant find the manual. Rear beam to floor and front cross member to floor.
Offline scud
« Reply #9 on: October 02, 2014, 18:04:38 PM »
you mean the Haynes Rob? iv got the v6 one no sign in there.
 but I bet 90mm on the crossmember is not enough
« Reply #10 on: October 03, 2014, 22:53:54 PM »
No. cosworth motorsport manual
Offline totsy
  • Chrome 38.0.2125.104 Chrome 38.0.2125.104
« Reply #11 on: November 10, 2014, 22:09:44 PM »
I've fitted Avo coilovers to my 24v XR4x4. Haven't set it up yet. you'll need to take a sledgehammer to the rear inner arch where the shock is mounted or the spring will get stuck.
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
Offline scud
  • Linux Linux
  • Safari 4.0 Safari 4.0
« Reply #12 on: November 14, 2014, 23:07:57 PM »
I'll look out for that cheers
