Author Topic: My Escort Mk2 is finally mapped.  (Read 15391 times)
« on: September 09, 2013, 14:04:58 PM »
It took almost  a year after fitting the turbo but finally had it done last week.
Running 0.8 bar/12 psi it made:
356 hp @ 6220 RPM.
411 Nm/302 ft/lb @ 5820 RPM.
Torque is a bit disappointing I think and could do with some improvement but at least it's very usable.
Re: My Escort Mk2 is finally mapped.
« Reply #1 on: September 09, 2013, 19:58:36 PM »
It looks good.
« Reply #2 on: September 09, 2013, 21:40:46 PM »
Spotted your car at fordfair but couldn't see you.
Is it a standard 24V with the turbo?
« Reply #3 on: September 09, 2013, 21:46:36 PM »
It's got lowered C/R pistons and running BOB cams.
Custom intake and exhaust manifolds.
Nothing done to the heads, they are bog standard BOA.
Offline v6gerry
« Reply #4 on: September 09, 2013, 21:59:53 PM »
yes good result but like you say TQ is down a little I bet your well chuffed  ;D
Offline mk2 cossie
  • Chrome 29.0.1547.66 Chrome 29.0.1547.66
« Reply #5 on: September 09, 2013, 23:47:36 PM »
Very nice indeed  ;D
Any pics of your finished turbo manifold?
And thats quite good going for 12psi isn't it?  :unsure:
« Reply #6 on: September 10, 2013, 09:02:57 AM »
Nice result mate , I bet that gets a shift on  ;D
Offline fordrwd4ever
  • 1.0 (eco)Beast...
  • Linux Linux
  • Safari 4.0 Safari 4.0
« Reply #7 on: September 10, 2013, 12:22:04 PM »
Let's hope it's dry next Sunday.
I want to make the next chapter of "Getaway in Landgraaf"..
(E.g. the sprint sessions...)
Should go well now it's mapped :)
Keep it very sideways..
Offline mk22door
  • Mac OS X 10.5 Mac OS X 10.5
  • Firefox 3.6.28 Firefox 3.6.28
« Reply #8 on: September 10, 2013, 13:54:28 PM »
Awesome  :ph34r:
Saw a photo of the engine from someone's FF pics, looks a nice car too
« Reply #9 on: September 10, 2013, 14:02:26 PM »
Offline v6gerry
« Reply #10 on: September 10, 2013, 20:07:11 PM »
Hi is this using the pistons you told me about ? do you have any pics of pistons ?
gerry
« Reply #11 on: September 10, 2013, 20:24:10 PM »
Yeah Jerry those are the pistons.
I only have this pic:
I can take a photo of a complete one if you want.
Offline Cortiworth IV
« Reply #12 on: September 10, 2013, 20:26:07 PM »
356 hp @ 6220 RPM.
140.4!! drag hp? Did they do the pull with the brakes on?
I'm not much into dyno testing, but something looks a bit odd here.
« Reply #13 on: September 10, 2013, 20:37:38 PM »
Well it might have something to do with the fact it's 4x4??
I always go to this dyno so it must be right?
Offline v6gerry
« Reply #14 on: September 10, 2013, 20:59:16 PM »
Thanks did you do any machineing to them ? if you have a pic would be nice to see what CR is your engine now ?
« Reply #15 on: September 10, 2013, 21:07:01 PM »
I'll take a pic tomorrow.
CR is a bit low, I think it's 7.5/1 so probably more suited to higher boost.
Offline v6gerry
« Reply #16 on: September 10, 2013, 21:16:58 PM »
I see they do 3 different bowl sizes , but don,t list dia of pistons
« Reply #17 on: September 10, 2013, 21:33:43 PM »
From the top of my head mine are 94.3 mm.
Offline v6gerry
« Reply #18 on: September 10, 2013, 21:37:50 PM »
ok thanks
« Reply #19 on: September 10, 2013, 23:44:57 PM »
Horse Power is O.K but peak torque is way down mate.
It looks like you have a boost issue, pity you couldn't have data logged it  :rolleyes:
On the run the boost came in late so you missed the mid range torque peak but was there for the end so HP was alright.
The torque plot will follow the spool of the turbo & you can see yours is flat until 3500rpm
You said before it's on boost around 3000rpm normally so you may have a wastegate problem again or something.
Once that's sorted you will be around 360lbs & the extra momentum will add a bit more HP which will be more like it.
Better still run a bar & it will be around 400 hp / lbs which is a nice place to be.  ;D :mellow:
140.4 hp of drag is a little high but only 20 hp or so for a 4x4.
MAHA dyno's measure actual drag on coast down so a rubbing brake pad, tyres low on pressure etc etc will show up.
  • Linux Linux
« Reply #20 on: September 11, 2013, 09:36:56 AM »
I found one reason for the high drag : the front left wheel bearing is fubared.
I fitted another dumpvalve as the old one started venting above 0.5 bar.
I don't trust this one either!! :angry:
I'll also try to disconnect the wastegate and see how it spools then.
« Reply #21 on: September 11, 2013, 14:58:39 PM »
Especially for Gerry:
Offline v6gerry
« Reply #22 on: September 11, 2013, 22:01:07 PM »
thanks for pic , still trying to find them might have to call them . what turbo are you using .
gerry
« Reply #23 on: September 12, 2013, 14:35:49 PM »
It's a GT3582 going from Dave's advice.
And for Dave: I went on a drive to day and wrote up the boost.
RPM vs Boost
2000  0.2
2250  0.3
2500  0.4
2750  0.5
3000  0.7
3250  0.8
  • 1.0 (eco)Beast...
  • Firefox 23.0 Firefox 23.0
« Reply #24 on: September 12, 2013, 18:44:37 PM »
Ok , i`ve uploaded the dyno run on YouTube
<a href="http://www.youtube.com/watch?v=l0yeabbC7MI" target="_blank">http://www.youtube.com/watch?v=l0yeabbC7MI</a>
« Reply #25 on: September 12, 2013, 21:22:04 PM »
That must be a right giggle  ;D
Offline Marc
« Reply #26 on: September 13, 2013, 17:56:05 PM »
Looking very nice!  ;D  Would be nice to have a look underneath the bonnet on Sunday.  :mellow:  I wouldn't mind a turbo on my 24v, maybe in the future...
'90 Sapphire Cosworth 4x4
'91 Sapphire 2.9 24v RWD
  • Linux Linux
« Reply #27 on: September 13, 2013, 18:44:46 PM »
If the weather is somewhat good I'll be there mate.
« Reply #28 on: September 13, 2013, 20:17:42 PM »
Sunday should be a dry day with some sun and 18 degrees.
  • 1.0 (eco)Beast...
  • Linux Linux
« Reply #29 on: September 13, 2013, 20:39:43 PM »
So i guess we will see your Capri too this time ?
