Author Topic: Help needed with boa conversion!!  (Read 4550 times)
Offline doga-ot
« on: March 30, 2013, 16:26:20 PM »
I'm currently in the process of doing my BOA conversion into my saph cossie, any how I have an XR4i subfame with engine mounts fitted and was told my BOA engine would fit straight in with standard BOA mounting arms however THEY DONT...
Distance between the engine mounts is 545mm and distance between mounting arm holes is 620mm
My question which arms do I need obviously I need shorter arms!
Cheer WES
Re: Help needed with boa conversion!!
« Reply #1 on: March 30, 2013, 19:13:21 PM »
You need the engine mounts from the xr4i. With some luck, you still have them on the old 2.8 that came out.
Offline doga-ot
« Reply #2 on: March 30, 2013, 19:30:15 PM »
Bud my saph is a 2ltr yb. I was told to use an XR4i subframe and to use Boa /XR4i/XR4x4 arms the Boa came with arms but don't  fit its fucked my hole weekend uo as I took Friday and Monday (for a long weekend) so to get whole conversion done.
« Reply #3 on: March 30, 2013, 20:04:35 PM »
The XR4 (RWD) arms are mounted on a steel crossmember and the 4X4 are mounted on an aluminium one. The 4x4 crossmember is different because there is more room for the front shafts.
Picture of the 4x4 cross member:
2.0 cosworth:
So you need the sierra v6 arms.
Offline doga-ot
« Reply #4 on: March 30, 2013, 21:15:13 PM »
This is my xr4i subframe im using the original boa (v6 arms) but they're to long.
As you can see distance between my engine mounts is 545mm and distance between my arms is 620mm
« Reply #5 on: March 30, 2013, 22:12:58 PM »
Can i ask why you fitted the XR4i crossmember?
The 2wd cossie one will fit to the BOA arms you have.
Offline doga-ot
« Reply #6 on: March 30, 2013, 23:04:29 PM »
Because my saph was originally 2wd but previous owner converted it to 4x4 I am fitting Boa and going back to 2wd I have my beam 7.5"diff shafts etc, front tca's shocks hubs rack.
  • Linux (Ubuntu) Linux (Ubuntu)
  • Firefox 16.0 Firefox 16.0
« Reply #7 on: March 31, 2013, 08:31:06 AM »
As stated, you need 2.8 XR4i arms.
Offline doga-ot
« Reply #8 on: March 31, 2013, 16:07:40 PM »
Thats what i'm after
« Reply #9 on: March 31, 2013, 22:36:10 PM »
or any 2wd sierra crossmember.
Offline doga-ot
« Reply #10 on: March 31, 2013, 23:41:06 PM »
Not really an option at this point for a few reasons,
I already have my engine mounts which are different on other subframes
My subframe is shot blasted and powder coated.
wes
