Author Topic: Scorpio cosworth parts if needed  (Read 4371 times)
Offline whiteestate
  • Mac OS X 10.7.3 Mac OS X 10.7.3
  • Safari 5.1.5 Safari 5.1.5
« on: March 14, 2013, 22:37:52 PM »
Im going to collect a bob engine the end of the month does anyone need any bits and pieces off the car as i think they maybe going quite cheaply ? Let us know what you need and i will see what i can sort out.
Obviously all engine parts will be for me but there is an auto box going and the car has only covered 70k.
Re: Scorpio cosworth parts if needed
« Reply #1 on: March 15, 2013, 20:55:34 PM »
I'm after the washer plates that go under the driveshaft bolts two holes per plate , like these but the 108mm ones
All  twelve if you could please Liam.  If the stub shaft is the same as a 2wd cos?  Yorevol was after those too.
Offline mk2 cossie
  • Linux / Sony Ericsson MT15iv Linux / Sony Ericsson MT15iv
  • Safari 4.0 Safari 4.0
« Reply #2 on: March 16, 2013, 01:50:04 AM »
If its got a good condition auto dimming rear view mirror, i'd like that please  ;D
Offline Dave2302
« Reply #3 on: March 16, 2013, 09:45:57 AM »
Hi,
If you're not going to use it I could use a PATS module, PATS LED and a short length of it's wire, Diagnostic OBD Socket with a foot or 2 of wiring, and EECV Plug with a foot or 2 of wiring, plus the key and key reader ring and the wiring wth plugs for that ;)
I am going to make a "Bench" rig in a box, to re flash and test the ECU's  ;)
Cheers Dave
It's nice to be important but
Offline whiteestate
« Reply #4 on: March 16, 2013, 12:50:55 PM »
Ok I'm going on good friday so hopefully will be able to get all these bits with a bit of luck
Offline Matt
  • 96' scorpio 24v, Edge Sport
  • Linux Linux
« Reply #5 on: March 16, 2013, 14:13:42 PM »
is the car a face lift version?
could you take a pic once collected?
Offline whiteestate
« Reply #6 on: March 16, 2013, 16:21:19 PM »
Hi Matt im not collecting the complete car just the engine and whatever bits anyone needs really i will contact the chap I'm buying the stuff off and find out what year the car is and will post a bit later.
« Reply #7 on: March 16, 2013, 22:06:49 PM »
That's great if you can  :angel:
Offline Dave2302
« Reply #8 on: March 18, 2013, 09:06:01 AM »
Terrific  ;)
Offline whiteestate
« Reply #9 on: March 18, 2013, 17:13:31 PM »
Haven't been able to get hold of the guy yesterday just tried again now so with a bit of luck he will get back to me with some answers !
Offline whiteestate
« Reply #10 on: March 18, 2013, 17:35:55 PM »
Good news is he's got 2 ultima's 1 in pieces and he does not know the age of the cars ?
Ade wants the drive shaft washers
MK2 cossie auto dimming mirror
Dave2302 pats stuff and chipped key
Yorevol wants the stub shafts ,
Will the stub shafts just pop out of the diff like normal splined units ?
« Reply #11 on: April 01, 2013, 15:44:11 PM »
Any joy Liam ?
Offline whiteestate
« Reply #12 on: April 01, 2013, 16:24:58 PM »
Not been able to get up there my driver let me down so I'm going to have to borrow a van from work but not going to be for a little while now as I'm having an op on monday so i will be out of action for a short while  :'(
Offline TimoXr4i
  • Safari 5.1 Safari 5.1
« Reply #13 on: April 01, 2013, 18:59:52 PM »
You need a fat torx bit to remove the stub axles, they are bolted with 6 torx bolts on both sides, and with a bit force you can pull the axles out!
Offline doga-ot
« Reply #14 on: April 01, 2013, 23:00:54 PM »
If there's another set of 108mm drive shaft washers like Ade wants i'll have them please bud
Cheers Wes
Offline yorevol
« Reply #15 on: April 02, 2013, 22:15:45 PM »
forgot about this, ive got some stubs now. rear vented calipers are now needed complete with carriers.
Offline TimoXr4i
« Reply #16 on: April 03, 2013, 12:15:11 PM »
Nice, what brakes did you use? I want mine vented too, so i need a pair of discs and callipers, disc brake lsd axle ihave laying around :ph34r:
Offline whiteestate
« Reply #17 on: May 01, 2013, 19:37:26 PM »
Last i knew the guy has scrapped both the cars and has no parts left,sounds very dodgy to me !  :police:
He was also supposed to be dropping the bob engine off to me this week but i have not been able to contact him but its not so bad as i do not have any space to put the engine any way sorry guys if i had your hopes up   :(
