Author Topic: Ford Sierras that i have owned.  (Read 25260 times)
  • MS Internet Explorer 10.0 MS Internet Explorer 10.0
Re: Ford Sierras that i have owned.
« Reply #30 on: April 02, 2013, 13:39:16 PM »
Like i said before, the old cam holder can be cleaned up and re-used after a line bore. However, you still need to pull the head for a line bore to get the correct clearance for the cam and cam holder.
Just changing the cam holder is a big no no. Not enough clearance and the cam will jam. To big clearance and the cam will flex and break.
I found this for you with in 5 minutes:
http://www.ebay.co.uk/itm/15-Ford-Scorpio-2-9-V6-Near-Side-Cylinder-Head-6-Mth-Warranty-Cosworth-/140868726187?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20cc6e2dab
£49.95  for a head with the cams, bargain. you just need some gaskets.
You could ask Melville if he sells head gaskets separately.
http://www.ebay.co.uk/itm/Cosworth-Granada-2-9-24v-BOA-V6-full-engine-gasket-set-/281033277222?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item416ee37f26
Archie.
« Reply #31 on: April 02, 2013, 16:01:51 PM »
I seen that head on for sale, its the offside head i need though & i want a head which has a rocker cover with it as well.
« Reply #32 on: April 02, 2013, 19:51:25 PM »
You could sent him a pm true ebay and ask if he has the other head.
You also could ask skinner http://www.fordpower.org.uk/forum2/index.php/topic,9668.30.html if he still has the head with the cam and bearing caps. Swap the bent valves with the valve of your head, and you have a good head.
