Any Ford mechanics on here.
Started by gengis, December 09, 2011, 14:13:20
gengis
I'm going to be replacing an engine on a 2007 Galaxy 2.0 tdci and want any info on how to do this. Is the engine on a subframe and drop down with the box and suspension. Thanks.
cossiemk2
I'd undo the gearbox to engine bolts.
Put a jack under the gearbox so it sits at a 30 degree angle.
And lift the engine out.
Refitting is a bit of a faf but unless you want to take of the subframe and taking out the engine/gearbox in one go, this is the easiest option.
I used to replace 2.0 diesel engines from Astras and Zafiras and taking it out from the top is the best bet by far!
