Rear tires are smoking
Started by Heiki, June 27, 2008, 13:13:27
Quote from: Simon 3 door
LMFAO in reverse? Ya on drugs fella? ROFL.
The engine still turns the same way. Had to look twice and then check the calendar to make sure it wasn't April 1st LOL.
that fact you could even be arsed to type that amuses me simon.... its a BS thread ment for amusment.... which i'm sure you knew anyway....
the lanugage difference makes me think twice but i guess they are stil entilled to a sence of humour.
Ian
Lets run with it for a mo    what would happen if you had a switch to reverse the polarity of the starter motor, so when you want to go backwards, you turn the engine off, flick said switch and then start it, huh, huh???
err i guess it would open the wrong cam first and explode in the plenum and you'd feel silly..... anyone want to try it and prove me wrong????
no, ive tried it in the volvo - did 140 backwards so i think i have the record   the turbo went shhhhit when i let off and the engine sounded like murb, murb      I went through a speed camera so i espect a cheques in the post to me too
