Granada cosworth and sierra with 24 valve conversion silicone hose kits.
Started by ShaunPC, December 04, 2007, 14:09:24
I think it doesn't really matter. It will fit both a Sierra and a Granny mkIII. The only major difference I can think of is that most Sierra 24v conversions tend to convert to leccy fans as well so you'd need to cut the tophose in 2 to be able to fit a fanswitch. Everything else is the same.
mouldytbags
ShaunPC
Quote from: mouldytbagseven if a 4i rad is used?
If you get a radiator for a 2.9 4x4 with air con they have a fitting for a fan switch so that you can connect up electric fans without needing to cut the top hose.
The kit fits in a sierra bay no problems as it was all test fitted on my car prior to samco puting them into production.
V6 POWER JUNKIE
If It Ain't Going Sideways I Don't Care!!
